Fitting 35" with as little lift as possible? - Page 2 - JeepForum.com
post #16 of 21 Old 01-18-2012, 07:35 PM Thread Starter
xtrmjeep
Thanks for the pics. I can see now where I need to cut. On my way back for getting the tires I started thinking I was going to need new flares. Guess Ill run them till I get $ for wider flares. I just came from mass from picking up the wheels and tires too. Jeep looks killer by the way!
xtrmjeep is offline
post #17 of 21 Old 01-19-2012, 05:57 PM Thread Starter
xtrmjeep
I did a test fit on the front today at work. Looks like Ill be highlining the front. I was thinking of just raising up the rear flares once I go to TJ flares and just do a lot of cutting. But I still think I need more room. So Ill most likely get a 2.5" lift. Ive run back 2.5" RE springs and loved em so might go that route.
xtrmjeep is offline
post #18 of 21 Old 01-19-2012, 07:32 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by xtrmjeep View Post
Thanks for all the input! I am either going DIY highline or start saving for Metalcloak fenders front and just alot of cutting in the back. NHfireYJ are you on exploringNH? I think I've seen your user name before. At the moment I do not have a body lift but was thinking of maybe a 1".
Yes ENH.com, same user name...
Def get a 1" or 1.5" BL
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #19 of 21 Old 01-20-2012, 05:16 AM Thread Starter
xtrmjeep
Sweet Im on there as well with the same name. Id rather not go with a body lift. But if I do i would only go with a 1". The other problem is the tires stick out about 5.5" from my stock flares. So Ill have to get extended flares or make my own.
xtrmjeep is offline
post #20 of 21 Old 01-20-2012, 06:24 AM
NHfireLJ
NHfireLJ's Avatar
I like the BL for the extra room, Makes working under and around the frame MUCH easier, and easier to get the mud and crap out too..
Def on the flares as the "Live free or die" State apparently means Live free or die as long as your tires don't extend more than 1/4 inch past your flares.... Brutal here on the seacoast...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #21 of 21 Old 01-20-2012, 06:57 PM Thread Starter
xtrmjeep
Maybe I will go with at least a 1" body lift. The previous owner put in a poly body mounts before I got the jeep so it should all come apart very easy. I used to drive around with no flares on one of my jeeps and I never got hassled but I just don't want to take the chance on getting a ticket.
xtrmjeep is offline
How to: Fitting 33x12.50's with a 2.5" Rough Country lift viperbluelx TJ Wrangler Technical Forum 19 05-25-2010 05:32 PM
fitting 35" tires... need help 91YJRockCrawler YJ Wrangler Technical Forum 39 04-17-2009 10:59 PM
First "Real" Post (60k service, fog light lens, and fitting 31" spare tire) LogicWavelength TJ Wrangler Technical Forum 5 08-13-2008 01:46 PM
36x12.5 tire (fitting under 4.5" lift) mattman8706 TJ Wrangler Technical Forum 18 01-21-2008 10:39 AM
Need advice on fitting 31"s packinheavy YJ Wrangler Technical Forum 9 02-10-2007 03:52 PM
