First time pulling transmission - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > First time pulling transmission
WJ Shackle Tabs: Tow-Hook Replacements2014 Spartan Locker Special - While Supplies Last! Dana 3FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 09-28-2014, 09:42 AM   #1
Rehtnug
I am about to pull the transmission to inspect and repair the clutch. I have the AX5
My question for those that have done this. Do I need to remove the transfer case shifter and mounting bracket in order to gain enough clearance to slide the transmission back to clear the input shaft of the engine?
Any help or advice would be great.
Its ready to come out. Only thing left is unbolting it from the block. Just want to check on this. My feeling is that it the bracket and shifter need to be removed from the tranmission and linkage disconnected from the transfer case.
Thanks for the Help!!!
Rehtnug is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 10:22 AM   #2
Deepsouth
I always remove both shifters and remove the T- case from transmission as well. They can be left together but it's a long heavy assembly.Only 6 studs hold them together. I always bench press the T- case back in because it is an odd shape to jack up.
Deepsouth is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 10:29 AM   #3
Rehtnug
Thanks.
Unread 09-28-2014, 05:39 PM   #4
pete1991YJ
Last time I did it, I left it all together and got my neighbor to help shove it all back in. He's a big boy. I didn't jack up the jeep at all, there's *just* enough room to wiggle the trans and t-case out from under it with the t-case shifter still on. I'll probably take the t-cas off the trans next time I have to do it simply because I'm getting older and weaker
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:05 PM   #5
jeep63
jeep63's Avatar
I've done this on 3 jeeps in the past 2 years, and I always separate the tcase from the transmission, and remove the tcase linkage/shifter assembly. It is much easier this way.
89 YJ - Locked and Loaded
91 YJ
95 YJ
jeep63 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:22 PM   #6
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
You can probably get by just pulling the shift boot ring in the cab, but I always pull the whole big trans hump cover plate. I've used that big hole to have a buddy use a strap from inside to help hoist it back, found it easier than using a jack under the trans. It's also makes it easier to get at the two top bolts of the t-case.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:53 PM   #7
jagular7
To put it back in, you have to align the snub of the input shaft into the pilot bearing and the splines of the input shaft with those of the clutch disc. Can be difficult to do while trying to level the trans and slide forward all at same time.
Take some 2-3" longer bolts that match the same threads as those on the side of the block (about 180* apart). Grind the head off and grind a slice across the shaft's face. These will help give you leverage to align the teeth and then the pilot as well as help slide the trans into position.
Before you put the trans back in, take the shifter and put into a gear. You can rotate the input shaft with the output shaft to get the teeth to align.
Anticipate fluid leakage with the tcase off the back. You can drain the trans before you pull it, but it won't all come out. To refill, pull the loosen the fill plug before reinstall. Once installed, tcase on back, before shifter is installed, pull the fill plug, pour fluid through shifter till it leaks out of the fill hole. Cleanup any spills, replace fill plug, shifter, tcase, rear ds. Check for tcase leaks once again. Put rear axle on jack stands. Start engine, go through gears (rear axle in air), check for leaks. If nothing, button things up - front ds, interior, and go for another street test under load.
It sounds bad, but not in reality. Make sure you use antiseize on those frame skid plate bolts. Have fun.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline   Reply With Quote Quick reply to this message
Unread Today, 01:10 AM   #8
Gausswave
IIRC it's only 3 bolts ( 2 mounting and I pulled the shift lever of the T-case.) and will make it easier to remove.
Gausswave is offline   Reply With Quote Quick reply to this message
Unread Today, 01:14 AM   #9
Gausswave
Sounds like a tight fit. I'm SOA on 33's and barely had enough room to clear the bell housing on the jack.
Unread Today, 04:29 PM   #10
Rehtnug
Thanks for all the info guys. I have already removed the transmission shifter arm but had questions about the t case shifter. I now have it removed as well. Big opening in the top as well. It is all ready. Bell housing bolts are loose with the top two removed. Only four holding it on right now.
So my question is this. When seperating the t case from the tranny, is there going to be fluid that will leak out?
I am in the process of getting a transmission jack to help make this process easier and safer.
I like the idea of the cut off bolt to help with allignment when reinstalling. Great call!! Good advice.
I would also like to leave the tranny and t case together to avoid the steps of having to remate them. It is possible to remove all together right? (Thats what the Chilton says to do) LOL I understand it will be easier seperated. I just don't want to do that if I don't have to.
Thanks again.
