First Time Installing a Lift Kit... Tips and Suggestions - JeepForum.com
post #1 of 11 Old 06-10-2014, 08:41 PM Thread Starter
scott45217
Im putting a Skyjacker 2.5" lift kit on my YJ, any tips or suggestions to make the job easier. It's my first time doing suspension work, besides installing my own shocks.
scott45217 is offline
post #2 of 11 Old 06-10-2014, 09:18 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Inventory all parts being installed and make sure they match what is supposed to be in the kit. Take pictures and measurements before and after. Spray down all fasteners you will be removing with PB blaster several times a day for several days before you begin the job. Do one side of one axle at a time. Lay out all the pieces to install alongside each corner in the proper orientation and with the proper fasteners/washers, etc. Take notes, follow the instructions, as questions. Take more photos, take more notes. Don't break out the beer until you are done with your job. Consider putting antisieze/grease on all fasteners. Final torque all fasteners to specification once the Jeep is on its own weight, sitting on the tires. Don't take risks, work in a flat area, don't substitute bricks for jackstands.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 11 Old 06-11-2014, 07:06 AM
pushead
Big hammer and a good sawzall. Cut every thing off you can vs trying too unbolt it unless you need the bolt.
Its not a jeep if it dont have 4wd.
pushead is offline
post #4 of 11 Old 06-11-2014, 09:49 AM
Que89YJ
Cut and torch. The spring bolts inbed themselves into the bushing. Cut x2.
Que89YJ is offline
post #5 of 11 Old 06-11-2014, 11:30 AM
bpounds
bpounds's Avatar
Get one end up in the air with jack stands under the frame. I doubled up the jack stands just to be safe. At that point you only need one good floor jack to lift an axle end off the spring.
If you've got a good kit, it goes in pretty easy.
I recommend ALL new fasteners, which you will want to source before you begin. You won't find it on a weekend around town.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 11 Old 06-11-2014, 11:32 AM
SeniorVerde
Soak & spray any bolts you need to turn with WD-40 or PB blaster now. Even if you don't plan on lifting the jeep for a week.
SeniorVerde is offline
post #7 of 11 Old 06-11-2014, 12:29 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Now I see why you sport that towbar in your avvy......Hides the hideous blue oval.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #8 of 11 Old 06-11-2014, 01:56 PM
329892 - Deactivated
Guest
Death by YJ !! That looks scary !!
329892 - Deactivated is offline
post #9 of 11 Old 06-11-2014, 02:09 PM
bpounds
bpounds's Avatar
Sharp eye. Most people don't even notice it.
Bill
bpounds is offline
post #10 of 11 Old 06-12-2014, 06:40 AM
Jake16JA
Just finished mine up last week, I bought a replacement spring eye bolt package which saved a bunch of time since you can cut all the old stuff out. I guessing that Massachusetts has the same rust problem as Michigan making it not worth the time to try to break anything loose. When I did mine I didn't realize how important removing the track bar was for lining up the leaf center eye bolts which led to a lot of frustration.
Jake16JA is offline
post #11 of 11 Old 06-12-2014, 10:14 AM
bpounds
bpounds's Avatar
It wasn't really. Rock solid support. But I guess it does look scary in the pics.
Bill
bpounds is offline
kit , lift , skyjacker , tips , YJ
