First jeep, slight problem. - JeepForum.com
post #1 of 24 Old 02-08-2013, 10:22 AM Thread Starter
Josh1986
Just bought my first jeep
its a 1988 YJ
it has
6" suspension lift
4" body
33 12.50 tires
4.11 gears
Holley carb
When i first start it it wont start unless i give it a little gas..
is this normal?
also it wouldnt start this morning.
tapped on the solenoid and it started right up..
any suggestions?
1988 YJ Wrangler 4.2 I6
6" skyjacker suspension lift 4" body lift
33 12.50 tires 4.11 gears
Holley carb
Josh1986 is offline
post #2 of 24 Old 02-08-2013, 10:25 AM Thread Starter
Josh1986
oh and when i first tried to start it this morning
it cranked once and i noticed a small puff of white smoke coming out of the steering colum.
would this have something to do with the solenoid?
Holley carb
Josh1986 is offline
post #3 of 24 Old 02-08-2013, 10:31 AM
Labhound
The solenoid doesn't use gas, it may have been stuck. If you still have the carter carb yes that's very normal to give some gas first. As far as the smoke from the steering colum..? There shouldn't be any.
Labhound is offline
post #4 of 24 Old 02-08-2013, 10:34 AM Thread Starter
Josh1986
it has a holley carb...
i just thought it was wierd that it wouldnt start..
i saw a small puff of smoke..
tapped the solenoid and it started back..
Holley carb
Josh1986 is offline
post #5 of 24 Old 02-08-2013, 10:39 AM
69moparman
First thing you'll want to do is run, don't walk, to your nearest store and buy a fire extinguisher.
You might have an issue with the ignition switch. Don't know the correlation between the switch and solenoid, I'm sure someone else can help there.
Yes, it's normal for a carbureted engine to start by feeding it some gas. Modern fuel injected cars have an electric fuel pump so you don't have to pump the gas pedal to start them.
69moparman is offline
post #6 of 24 Old 02-08-2013, 10:40 AM Thread Starter
Josh1986
so you think i need to pull the colum off and check the wires?
Holley carb
Josh1986 is offline
post #7 of 24 Old 02-08-2013, 10:49 AM
69moparman
You shouldn't have to pull the column, the switch is mounted to the column and is connected to the key tumbler be a rod. The switch can be removed without dropping the column.
post #8 of 24 Old 02-08-2013, 10:49 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If it were my Jeep, I'd immediately disconnect the battery, then start troubleshooting that electrical issue asap.
When it made a puff of smoke - did it smell?
Don't wanna end-up like this:
Joe Dillard is offline
post #9 of 24 Old 02-08-2013, 10:51 AM Thread Starter
Josh1986
yea it had an electrical smell to it
Holley carb
Josh1986 is offline
post #10 of 24 Old 02-08-2013, 10:53 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have got to see what a four inch body lift looks like. And a six inch suspension lift with 33's.
Please post pics for posterity's sake.
Luck Favours The Prepared
Anticanman is offline
post #11 of 24 Old 02-08-2013, 10:53 AM Thread Starter
Josh1986
alright i'll get a few in a min..
i do plan on taking the body lift off lol
Holley carb
Josh1986 is offline
post #12 of 24 Old 02-08-2013, 11:12 AM Thread Starter
Josh1986
ok went out to start it and it cranks maybe 1-2 times then stops everytime i turn the key?
Holley carb
Josh1986 is offline
post #13 of 24 Old 02-08-2013, 11:27 AM Thread Starter
Josh1986
so i got it started and found that my turn signals have quit working...
i'm guessing the smoke was the turn signal wire burning?
still having the issue with the started but it will start if i keep trying..
guessing i need a new starter/solenoid..
sucks that i just bought the thing yesterday.
Holley carb
Josh1986 is offline
post #14 of 24 Old 02-08-2013, 11:40 AM
Rproject
1987 YJ Wrangler
From the sound of it, a carbureted motor is something new to you. If not, the next few lines will be redundant and insulting. I apologize in advance if they are.
How I start my '87:
- put the pedal to the floor 1 time and release.
- turn the key
- the engine should start and idle between 1500-2000 rpm
- when the temp gauge starts to get close to the first line above bottom, tap the gas about half way down and release (this will release the choke)
- engine should now idle between 600-900 rpm.
- drive away
The smoke from the column needs to be looked immediately, if not sooner. If it smelled, and you're losing functionality in the column (eg turn signals), something shorted. Get it fixed.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #15 of 24 Old 02-08-2013, 11:51 AM Thread Starter
Josh1986
thanks i appreciate the help.
and yes only thing i've owned with a carb is 2 stroke dirtbikes..
Holley carb
Josh1986 is offline
