First Build 1991 Renegade to NORMAL YJ. - JeepForum.com
post #1 of 28 Old 01-11-2012, 11:11 PM Thread Starter
ParkerJ
Hi everyone!
I just finished my very first Jeep Wrangler rebuild and figured I'd share the pictures with everyone. First off I'd like to state that I am an amateur mechanic at best and without the big help of friends and family none of this would have came together. This was a huge labor of love taking near 10 months to finish just due to time constraints and learning curve (law school, work, wife, kid etc)
I bought this Jeep for 2000 and it was my first wrangler ever. I always wanted to own one and couldn't pass up the the deal however, the renegade body kit is horribly ugly! And so began my first Wrangler rebuild...Enjoy
ParkerJ is offline
post #2 of 28 Old 01-11-2012, 11:12 PM Thread Starter
ParkerJ
Here are the original Jeep when I bought it. Looks good eh? Looks as all wrangler users have come to find out can be deceiving!
ParkerJ is offline
post #3 of 28 Old 01-11-2012, 11:18 PM Thread Starter
ParkerJ
After removing all the body "armor" of the renegade kit we found all the fun and then some of body rust! The body and frame on this thing was a nightmare! I didn't think to take any photos of allll the rot but here is a photo of the frame and body upon seperating them. Notice all the fun holes left behind by the awesome renegade body kit!
ParkerJ is offline
post #4 of 28 Old 01-11-2012, 11:22 PM Thread Starter
ParkerJ
After the body and frame were seperate we started to attack the frame first. Luckly the frame was relatively solid. There was only two bad spots (both under the radiator). After a good sanding I painted the frame a firehouse red to work with the black.
I also as you can see put on new gaskets, cleaned up and painted the transmission and engine. What you also don't see is brake, fuel and emergency lines. As exspected, every line was rusted out to the point of no return and would need replaced!
ParkerJ is offline
post #5 of 28 Old 01-11-2012, 11:28 PM Thread Starter
ParkerJ
After getting all the lines and frame in order it was time to start on the body. I started as a novice welder and after this project feel like an expert lol. A fun fact about Renegade Jeeps is how much they utterly DESTORY the Jeep itself to put on the plastic body kit. I had to completly fabricate new fenders as they were cut out to have the kit put on.
The backend and tailgate were also rusted to no return and needed to be fabricated as well.
Also upon inspection of the tailgate it seems someone had wrecked into the back of it. So I had to cut it open, rehammer it straight, weld it close and fix the holes in it! *note to self, buy a new one next time
ParkerJ is offline
post #6 of 28 Old 01-11-2012, 11:32 PM Thread Starter
ParkerJ
Next phase of attack was all the rust on the body, FLOOR PANS and support brackets. What a nightmare! Those renegade kits held water perfectly to rust a jeep out!
In this photo you see a ton of mig welds...that's where Jeep had drilled holes to hold the renegade body kit on!
ParkerJ is offline
post #7 of 28 Old 01-11-2012, 11:35 PM Thread Starter
ParkerJ
Once all the holes and rust were removed it was time for some preventative action! Time to undercoat that body!
Upon further decision I added an extra layer of primer just to be safe! Note my father in law spraying on the undercoat. You can also see were the floor pans had to be replaced.
ParkerJ is offline
post #8 of 28 Old 01-11-2012, 11:39 PM Thread Starter
ParkerJ
Now it was time to put the body back on the frame after all the lines had been replaced and everything painted and sealed!
New front brakes and with body on the frame.
New Warrior skid plate since OBV the original was rusted away.
ParkerJ is offline
post #9 of 28 Old 01-11-2012, 11:40 PM Thread Starter
ParkerJ
Once the body was on we threw on rhino lining on the inside of the tub as well to insure that this body would avoid rust best as possible!
ParkerJ is offline
post #10 of 28 Old 01-11-2012, 11:41 PM Thread Starter
ParkerJ
I forgot to mention that we also installed a 2" body lift while putting the body back on as well as new body mounts and rear brakes.
ParkerJ is offline
post #11 of 28 Old 01-11-2012, 11:43 PM
SnowYJ
1988 MJ Comanche
Wow man, thats some good well you did! Awesomemseeing it come back to life. On a side note, you may want to cut down or replace that 2" bl with a 1"
I go to college and I drive a Jeep.
SnowYJ is offline
post #12 of 28 Old 01-11-2012, 11:44 PM Thread Starter
ParkerJ
So at this point it was time to the roll this bad boy into the garage for body work! Wouldn't you want to cruise this bad boy downtown haha.
O yeah, forgot this fun...
ParkerJ is offline
post #13 of 28 Old 01-11-2012, 11:45 PM Thread Starter
ParkerJ
Was debating it after I put on my lift but without that body lift I couldn't fit my 31s haha. Thanks on the compliment!
ParkerJ is offline
post #14 of 28 Old 01-11-2012, 11:48 PM Thread Starter
ParkerJ
At this point I filled in all the errors, dents, etc and began the body work process. 100000 hours later of sanding the jeep was ready to be primed.
Old renegade door prior to priming.
New primed door
Primed and ready to go.
ParkerJ is offline
post #15 of 28 Old 01-11-2012, 11:50 PM Thread Starter
ParkerJ
This thing needed sooo much sanding and body work but the outcome was fantastic!
Post Painting:
ParkerJ is offline
Pimp my ride - 1991 Renegade Cisco93jeepYJ YJ Wrangler Technical Forum 10 09-20-2015 06:37 PM
Tools to Bleed Clutch on 1991 Renegade I6 Cisco93jeepYJ YJ Wrangler Technical Forum 2 11-20-2010 07:42 AM
1991 Jeep Renegade tannermorrow YJ Wrangler Technical Forum 8 02-25-2010 09:42 PM
1991 YJ Renegade ? brk913 YJ Wrangler Technical Forum 3 04-19-2006 02:35 PM
1991 Jeep Renegade shakes!!! jrenegade13 YJ Wrangler Technical Forum 1 05-04-2003 06:45 PM
