Firing order 2.5 - JeepForum.com
post #1 of 2 Old 09-18-2012, 01:01 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So I know the order is 1 3 4 2, but I am wanting to know if this diagram is right as far as the distributor cap goes? I only ask because I have seen a few different setup...... And I am trying to track down a intake back fire on my 93 2.5 and thought maybe I have a wire crossed.
zte87 is offline
post #2 of 2 Old 09-18-2012, 01:08 AM
5-90
5-90's Avatar
1988 XJ Cherokee
The order should also be cast into the intake manifold.
For determining #1 on the distributor, remove the plugs and turn the crank by hand. Have a helper hold their finger over the #1 plug hole - if you're TDC firing, you'll have pressure buildup in the cylinder. If you're not there, both valves will be open and there will be no pressure.
Typically, the relative locations of the towers is important - notice the two protrusions from the outer perimeter of the drawn cap? Those are the holddowns, and those are going to determine where you find #1 on the actual dizzy (which has likely moved.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
