Quantcast Finished my SOA and high steer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Finished my SOA and high steer
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 07-20-2009, 12:43 PM   #1
Jedidiah
1995 XJ Cherokee
Finally finished doing my SOA and high steer setup. Just thought I'd post a few pics to see what you guys think.
It was a lot of work but fairly straighforward. I'm really happy with the way it rides compared to the 4.5 XD sua setup I had before this.
I still need to cut off the old shock mounts and mount some new ones higher up on the axle tube. I'm gonna try to get to that this weekend.
When I replaced the old steering knuckle with the new high steer knuckle I found out I had to replace the ball joints but that was the only hitch in the entire install.
I definetely need bigger meats under there. YJ is sitting on 33x12.50 TSLs
By the way, I'm horrible with pictures, so, this is the best I could do.
Jedidiah is offline   Reply With Quote
Old 07-20-2009, 12:45 PM   #2
timatoe
Jello Puddin'
timatoe's Avatar
What high steer knuckle did you use?
timatoe is offline   Reply With Quote
Old 07-20-2009, 12:49 PM   #3
Jedidiah
1995 XJ Cherokee
I used the whole Teraflex high steer kit which includes a new knuckle
Old 07-20-2009, 12:55 PM   #4
YJames90
aka Jamesx2
YJames90's Avatar
Nice. Im right behind you in progress.
What size springs are those?
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is offline   Reply With Quote
Old 07-20-2009, 12:58 PM   #5
Jedidiah
1995 XJ Cherokee
They are the Rubicon Express 1.5 inch spring over leafs
Forgot to mention, I also have a 1 inch body lift.
Old 07-20-2009, 01:54 PM   #6
timatoe
Jello Puddin'
timatoe's Avatar
Originally Posted by Jedidiah View Post
I just noticed in these two pics, you're springs are mounted in the center bolt position, but they are right in the other two. Just making sure you have them all right (like the other pics) The shackles won't function properly the way they are in these pics.
Old 07-20-2009, 02:31 PM   #7
Piet
I have 1.5" lift springs, SOA, and a 3/4 body lift and TJ Flares.
I am running 37's comfortably. (It is a YJ... just has a CJ front end)
- Peter ----------- Canadian Jeep Club Member #1969
2008 Jeep Wrangler JKU Rubicon "Ubercon" - 3.8L V6, 6 Spd Manual, RockTrac with Dana 44's on 32's. Mostly stock for now...
SOLD - 1988 Jeep Wrangler "Golden Eagle" - 350 TBI, NV4500, Dana 300, Detroit Locked Dana 44, Spooled 9", SOA, 37" MTR's
SOLD - 1994 Jeep Wrangler "Oliver" - 4 Cylinder Stocker on 31" Kuhmo MTs
Piet is offline   Reply With Quote
Old 07-20-2009, 02:37 PM   #8
YJames90
aka Jamesx2
YJames90's Avatar
No rear drive shaft problems? I cant get my chero DS to drop far enough. I also have to extend the front DS
Old 07-20-2009, 02:44 PM   #9
timatoe
Jello Puddin'
timatoe's Avatar
After looking at you're pics again, I think I'm just seeing things wrong. It looks like your springs wrap from top to bottom, instead of bottom to top like mine, giving it the appearance that they're in the middle. Sorry for any confusion.
Here's what mine look like so you see what I'm saying from a side view.
Old 07-20-2009, 03:11 PM   #10
TSEJEEPERS
RE springs wrap the other way from other springs.
Since I brought up the word wrap did you install a traction bar?
Nice looking Jeep!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 07-20-2009, 04:48 PM   #11
Jedidiah
1995 XJ Cherokee
Nice looking Jeep!
Not yet but that is one of the next things on my list.
Glock Forum
