Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > YJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 01-30-2009, 12:36 PM   #1
ritjobbie
I hate mud.
ritjobbie's Avatar
finished body lift, now its hard to steer
I just finished a 1.25" JKS BL today. Now it is harder to turn the steering wheel. It's not like the manual steering on my old Toyota, but pretty close. The slip-joint on the steering shaft looks a little cruddy, so I sprayed some PB on it for S&G. The little u-joints in the steering shaft seem to be at conservative angles compared to other BL'ed Jeeps I've seen.
The PS pump isn't squealing and I don't see any PS leaks.
Anything quick and easy I can check before I start hitting things with a BFH?
Thanks!
1995 YJ Rio Grande, 2.5L Low Output Engine
My Jeep Worklog
ritjobbie is offline   Reply With Quote
Old 01-30-2009, 01:04 PM   #2
idaholtby
idaholtby's Avatar
I know that on 2" BLs you usually have to remove one of the clips in the slip joint on the steering shaft to allow the slip joint to extend further to accommodate the extra length due to the lift. It is either that and/or your slip joint could be froze up. I actually had to temporarily weld two pieces of steel on either side (one to rest on and the other to beat on) and used a sledge hammer to break it free. Then ground off the welds to remove the attached steel.
idaholtby is offline   Reply With Quote
Old 01-30-2009, 02:28 PM   #3
ritjobbie
I hate mud.
ritjobbie's Avatar
Like I said, my slip joint does look kinda' crappy...
I drove it around the block just a few minutes ago. If I'm turning and I let go of the wheel, the wheel doesn't straighten out. The tension in the wheel is almost definitely in the steering column, not the PS pump/gear.
I'll give the slip-joint a good once over. Thanks!
My Jeep Worklog
Old 01-30-2009, 04:30 PM   #4
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
The slip joints only have to slip in an accident. They stay fixed in day to day use, which means they crud up rock solid over the years. Thats one of my pet 'to do soon' projects, buying a nice replacement (and a junk yard Durango gear box).
Spray it with PB Blaster, wait an hour, then tap it with a hammer. It's already under tension, so it may pop out a bit.
'93 YJ, '02 GM 4.3 Vortec V6, SOA w/1.5"RE leafs, dual ARB's, 8.8+D30(w/TJ shafts & Warn Hub Conv), 4discs, 4.88 gears, 35" Trxus M/T's, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000+Syn, no top or doors. Apr-Oct.
=> Member and Officer in the Hudson Valley 4 Wheelers
=> Vice Chair of Northeast Offroad Vehicle Alliance (NOVA)
JeeperDon is online now   Reply With Quote
Old 01-30-2009, 04:42 PM   #5
jamesx2
Jeep Junkie
jamesx2's Avatar
I had the same problem. I loosened up the clamp where the steering column meets up with the shaft on the splines section. I then slid the column off the shaft just a hair with enough to free up the steering but also enough so the two parts are still safely secures
1990 YJ
2.5 Low output , 5 speed standard
4 wheel drive hardware 2 inch spring lift SOA
Rubicon Express hand throttle
Posi-lok
M.O.R.E 5/8: lift boomerang shackles
Aussie locked front and rear
JB4x4 SYE
No trackbars
No swaybar
Smittybilt 8000# winch
Swamper Trxus M/T 35x12.5x15
15 x 7 AR-767 rims
OBA
Pontiac sunfire front seats
Full cage
Member of http://www.hv4w.org/
[color=Black]
Originally Posted by Pokeman View Post
I'll get you a picture. dont be a punk.....
RIP RSG
jamesx2 is offline   Reply With Quote
Old 01-30-2009, 07:12 PM   #6
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Originally Posted by jamesx2 View Post
I loosened up the clamp where the steering column meets up with the shaft...then slid the column off the shaft just a hair
That may work, obviously did for you, but those clamps for the column and for the box input have a grove in them for the clamping bolt. Those groves keeps the u-joints position on the spline shafts mostly fixed, so your technique may not work for everyone.
Old 01-30-2009, 07:55 PM   #7
abbottg
Junior Member
1987 YJ Wrangler
You may also want to take a look at the PS lines, esp the two steel sections going into and out of the gear. They are tight by the L frame rail under the rad support and can get pinched. A restricted line will negatively affect the assist your PS pump can give it and make it feel more like manual steering.
abbottg is offline   Reply With Quote
Old 01-30-2009, 09:15 PM   #8
ritjobbie
I hate mud.
ritjobbie's Avatar
I could totally see that happening, but mine appears to be related to the slip-joint. My diagnosis: the slip joint didn't move at all when I did the BL and now the shaft is pushing HARD toward the firewall from the PS gear. The pressure is creating friction between in the steering column (I can hear things rubbing that don't normally rub) and it makes it super hard to turn the wheel.
I'll take pics tomorrow and post back. Everyone likes pics.
My Jeep Worklog
Old 01-31-2009, 05:28 AM   #9
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
You know what it is, know a few ways to fix it, why don't you just fix it rather than taking photos. We all know what a steering shaft looks like.
Finished my SOA and high steer Jedidiah YJ Technical Forum 10 07-20-2009 03:48 PM
HP44 and hi-steer FINALLY finished admar2 YJ Technical Forum 49 02-04-2007 11:54 PM
How hard is it to install a body lift?? NEWtoTHEjeepLIF TJ Technical Forum 14 08-14-2005 01:52 PM
How hard is a body lift. TheHerald YJ Technical Forum 8 01-06-2004 09:21 PM
Finished my 3" Body Lift on my TJ Sahara!! Matt Graham TJ Technical Forum 3 01-01-2002 02:15 PM
The time now is 05:32 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
