Fine vibration in steering wheel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Fine vibration in steering wheel
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 09-26-2011, 08:17 AM   #1
castorriver
My stock 95 YJ 4cyl 5-speed has a lot of fine vibration in the steering wheel at any speed over 20mph (in 2wd). It's always there and nothing seems to make it worse other than engine rpms. Any ideas on what I could do to fix it? I put on one of those gel steering wheel covers which helps a little.
This jeep runs straight with no problems up to 70mph.
My old CJ7 didnt vibrate like this.
castorriver is offline   Reply With Quote Quick reply to this message
Unread 09-26-2011, 08:34 AM   #2
bhartwell59
1987 YJ Wrangler
motor mounts?
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline   Reply With Quote Quick reply to this message
Unread 12-30-2011, 09:58 PM   #3
castorriver
I replaced the motor mounts on the jeep and still have a lot of vibration but it feels different, hard to describe but still there. The left rubber motor mount was broken in half and the right was torn about halfway across.
I also installed a Borgeson steering shaft with vibration reducer and that helped a little.
On the road the vibes go away if I push in the clutch and let the engine coast and almost is completely gone until I give it gas. Next I guess I'll change out the transmission mount, and I ordered a new steering damper.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
Unread 12-30-2011, 10:06 PM   #4
dillonjm
30mm@70/sec
dillonjm's Avatar
My guess was maybe the tranny mount. Its weird that you feel it only through the steering wheel though.. puzzling.
03 Rubicon (Weekend Toy) Build thread
11 Ram 2500 - H&S tuned 6.7 Cummins (DD/Tow Rig)
05 Liberty Limited (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 12-30-2011, 10:28 PM   #5
castorriver
The body does shake, but maybe it didn't seem to be a problem in my mind when I started the post so I didn't mention it. I'll bet that would have helped you guys diognose it.
The Borgeson steering shaft did help tighten up some of the slop I had in the wheel.
Unread 12-31-2011, 04:53 AM   #6
bogleparsons
Its just the "massage feature"
Mine gives you a good backrub too, kinda nice after a day of ruff off road .
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote Quick reply to this message
