Finally got my 8.8 swap done(well mostly done) - JeepForum.com
post #1 of 18 Old 06-17-2009, 09:23 PM Thread Starter
jeeper87
1987 YJ Wrangler
So for I have gone through 3 dana 35 rear axles before going with something more heavy duty. And none of the damage was done offroading it was all on the street I have a lead foot. That 4.2 L has a lot of torque. I got axle in everything hooked up. The whole process actually went pretty smoothly. I still donít have the parking brake hooked up yet. I bought the kit from M.O.R.E. that is supposedly to fit exactly; well if I did it again I wouldnít have wasted my money on it, it doesnít fit it is too long where it connects to the single cable so I need to make some spacer or something. I havenít yet figured out how I want to get it modified so it will work. The ford 8.8 was out of a 2001 explorer with 4.10 gears, and disc brakes obviously.
jeeper87 is offline
post #2 of 18 Old 06-17-2009, 09:31 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The MORE kit is geared towards those who are going SOA at the same time & not staying SUA. I suspect that this is the reason you are not happy with it.
Did you speak with Allen at MORE before you purchased the kit & explain your swap?
Joe Dillard is offline
post #3 of 18 Old 06-17-2009, 09:49 PM
Fun2Jeep
1997 XJ Cherokee
I reused the Ford cables and everything worked great. It was really easy.
Fun2Jeep is offline
post #4 of 18 Old 06-18-2009, 05:41 AM
Matt_vs_YJ
And if you don't get the Ford cables with the axle (like me) then NAPA has the stock replacement cables for about $60.
P/N 95427 and P/N95064
Matt_vs_YJ is offline
post #5 of 18 Old 06-18-2009, 05:44 AM
1998zj
Or you can get a couple 1/8 cable thimbles and wrap the cable around the parking brake arm and tighten them up. Just need to cut off a few inches of the spring. Only costs you a couple of bucks.
1998zj is offline
post #6 of 18 Old 06-18-2009, 06:49 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Or you can do this, from Tom Wood. You then also get a x4.10 improvement in holding strength (or x4.88 in my case). I found the Ford setup was marginally effective in the driveway, and did not do well at all on the trail.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #7 of 18 Old 06-18-2009, 08:34 AM
chupacabrah
chupacabrah's Avatar
that is what I NEED!
gotta look into that
I have the MORE kit thing, and I rigged it up to extend the cable so it works. but the 8.8 ebrake is still marginal at best.
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #8 of 18 Old 06-18-2009, 08:53 AM
jeepster93
jeepster93's Avatar
Be aware...
That ebrake kit from Tom Wood, only works with an Advance Adapters(AA) sye, no others.
Has to do with the grinding of a certain surface.
jeepster93 is online now
post #9 of 18 Old 06-18-2009, 09:07 AM
JeeperDon
JeeperDon's Avatar
Originally Posted by jeepster93 View Post
Be aware...
Very not true. It mounts to most any flat plate style drive shaft mount, not a yoke mount. The silver colored part on the left end of the drive shaft is a standard Spicer part and the disc's bolt holes are for that pattern. I mounted mine forward of the t-case output flange (brownish plate) for other reasons, but the disc normally sandwiches between the Spicer part and the t-case output plate.
Web Admin for
post #10 of 18 Old 06-18-2009, 10:38 AM
chupacabrah
I have an AA SYE, but I have a yoke and not the plate adapter piece....dang.
-Jon
post #11 of 18 Old 06-18-2009, 10:42 AM
Allen52105
what is that brake called... slip yoke eliminator disc.lol seriously though. is that thing legal to use and not have brakes on the rear axle. anyone got a link to the site that sells them. I am going to be doing a 8.8 swap and that looks interesting
jason
Allen52105 is offline
post #12 of 18 Old 06-18-2009, 11:56 AM
JeeperDon
JeeperDon's Avatar
Legal? It works better than what it replaced. Look at all the other things we do to these trucks that could have more grave consequences, and we never question legality. I can tell you that I can full press the Jeep parking brake pedal and fully stop my Jeep idling in 1st gear low range (with 4:1 and 4.88). That's pretty hard to do with regular brakes. Here is the link to the kit I used.
Web Admin for
post #13 of 18 Old 06-18-2009, 11:40 PM Thread Starter
jeeper87
1987 YJ Wrangler
here is some pictures i am not sure if i should move the bracket and weld it back on or to make a spacer to go between the washer and the bracket that connects the two rear cables to the single cable.
http://cid-203b2d7947c52599.skydrive...00%7C_0459.JPG
http://cid-203b2d7947c52599.skydrive...00%7C_0460.JPG
jeeper87 is offline
post #14 of 18 Old 06-19-2009, 05:32 AM
chupacabrah
you could snip those 2 cables and put new ends on. that would be simple enough
-Jon
post #15 of 18 Old 06-19-2009, 08:41 AM
JeeperDon
JeeperDon's Avatar
You could never put ends on well enough as those are on, not for the pressures involved. I would put a tubing sleeve a few inches long behind the nut on the main cable.
Web Admin for
Ford 8.8 swap...Finally sebastian22 YJ Wrangler Technical Forum 364 07-03-2017 10:39 PM
My 8.8 swap is finally finished! Fun2Jeep YJ Wrangler Technical Forum 26 07-10-2009 08:29 PM
Finally My Turn! 4.0 / AW4 swap in my 89 YJ. good bye 2.5! Big-n-Broke-YJ YJ Wrangler Technical Forum 81 12-10-2007 11:18 AM
My Swap is FINALLY! ALIVE!!!!!! gigamitch YJ Wrangler Technical Forum 7 01-03-2007 10:10 PM
started my v8 swap..finally krayniac YJ Wrangler Technical Forum 2 04-13-2006 02:00 PM
