Finally found a fix for Steelhorse hard door uppers - JeepForum.com
post #1 of 7 Old 03-08-2007, 05:50 PM Thread Starter
jazzplr
I've been battling with tightening my Steelhorse hard half door uppers for some time now. The problem is that they actually had a good design with the threaded pin inserts that the uppers screwed into but since they've gone out of business you can't find replacement parts anywhere. I started out using these inserts used for wood that was thin sheet metal and would kind of create new threads for the bolts to tighten to. Unfortunately, they still wouldn't snug up all the way and felt stripped. My solution was to buy a Helicoil copy cat from Autozone for $20 that included the tap, 3 inserts and the installation tool. I then took the factory inserts and removed the spring metal from the bottom and tapped them from the bottom up. After installing the thread inserts the uppers tighten down very well and act much more like full doors now.
Too bad warm weather is around the corner and with a little more work convincing my wife, I will be moving to a soft top for the summer.
Hero's aren't born, they're cornered
jazzplr is offline
post #2 of 7 Old 03-08-2007, 06:17 PM
NewdRiver_
Does this mean my Steel Horse step bumperettes are antiques? Cool!
NewdRiver_ is offline
post #3 of 7 Old 03-08-2007, 07:24 PM
Flashfoto
I wished you woulda posted an info request......I got their 2-piece HT and hard upper's given to me & had to buy the threaded door insert's & a couple of clasp's. I called these guy's & had them in less than a week.
STEEL HORSE AUTOMOTIVE
601 W. Walnut St.
Compton, CA 90220
800-533-7704 fax 310-537-3210
Supplier is 4 wheel specialist
1-800-792-2612
Flashfoto is offline
post #4 of 7 Old 03-08-2007, 08:17 PM Thread Starter
jazzplr
601 W. Walnut St.
Compton, CA 90220
1-800-792-2612
Man, I should have thought about that! I was under the impression that since they went out of business you couldn't get any replacement parts.
jazzplr is offline
post #5 of 7 Old 04-21-2007, 07:32 PM
Gardels
Good tip on the helicoil..... worked awesome for me!!
Gardels is offline
post #6 of 7 Old 04-21-2007, 09:16 PM Thread Starter
jazzplr
I'm glad I was able to contribute to the community!
jazzplr is offline
post #7 of 7 Old 04-21-2007, 09:19 PM
lutzke21
Yep, old junk...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
Half Steel Door Hard Uppers ?'s 06Sport TJ Wrangler Technical Forum 13 09-15-2009 12:14 PM
hard top with soft door uppers Brew461 TJ Wrangler Technical Forum 2 10-29-2008 02:25 PM
Hard Top - Half Door Uppers roadking TJ Wrangler Technical Forum 2 11-21-2006 08:19 PM
Steelhorse uppers... lifeguard4_00 YJ Wrangler Technical Forum 2 05-24-2004 02:09 PM
1/2 door hard uppers??? Scafone TJ Wrangler Technical Forum 1 09-08-2002 07:40 PM
