Finally completed the Howell install. Lots of pix. - Page 2 - JeepForum.com
 4Likes
post #16 of 59 Old 09-10-2010, 07:53 AM
jth0033
1987 YJ Wrangler
Awesome write up... I have to do this myself some day, enjoying the carburetor for now though. Question, where did you get the attachment on the air cleaner, plastic piece that goes for square to round on the end? Thanks and great job!
jth0033 is offline
post #17 of 59 Old 09-10-2010, 12:17 PM Thread Starter
jbolty
jbolty's Avatar
same as the air cleaner. I think it was an astrovan or an s-10. something with a 4.3 in it.
jbolty is offline
post #18 of 59 Old 08-26-2011, 09:42 PM
tommbstone
Is there anyone in the central valley or close willing to help me install this kit on my 89 wrangler. Pm me details price etc
tommbstone is offline
post #19 of 59 Old 08-01-2012, 08:20 AM
TheSmanman
Excellent write up! Enjoyed the read.
TheSmanman is offline
post #20 of 59 Old 08-05-2012, 02:36 PM
csrguth
For anyone with an airconditioner beware the relay box (for the stepper motor) and the diode box next to it are still necessary. I found out the hard way when I dicided to finish cleaning up my working Howell TBI wiring. I also did something that resulted in the Jeep going dark when I turn the ignintion - still trouble shooting that.
csrguth is offline
post #21 of 59 Old 02-28-2013, 07:43 PM
mncdriver
1987 YJ Wrangler
I started my install tonight, stripped all old wires out, working on ECM mount, your pictures is what I needed. Im sure I will have to keep refering to your writeup as I go along.
mncdriver is offline
post #22 of 59 Old 03-03-2013, 07:51 AM
mncdriver
1987 YJ Wrangler
Question, what source wire did you use for the 12 power and switched under dash?
post #23 of 59 Old 03-03-2013, 03:35 PM
timatoe
timatoe's Avatar
Just an option. When I did the ECM on mine I used a big hose clamp (like for dryer ducting) it was couple dollars at the local hardware store and clamped it to the stock mount. Similar to Jeff's setup, but I didn't have any strapping laying around and saw the clamp first at the store.
Mine could be different, but there was a yellow wire under from the column that is the switched 12v, I ran that to trigger a relay that feeds a solid 12v direct from the battery to the system.
timatoe is offline
post #24 of 59 Old 05-11-2013, 10:54 AM
NonRubicon
Just answered a question today about where the wires attach to the starter and figured it might be good to add to this FAQ.
Here's where the wires attach to the starter assembly:
Here's a diagram to help locate the 12V switched wires in the computer harness:
Per the instructions provided by Howell, you can retain either the #1 or #57 (yellow) wires to power the TBI computer. This is how I wired up my 12V power. If it doesn't provide enough direct voltage, it can be still be used to trigger a relay as like what timatoe did with his setup.
NonRubicon is offline
post #25 of 59 Old 10-15-2013, 03:57 PM
johnpainter
I consulted this post before I did the Howell kit on my 1990 YJ--so, thanks! I made a video of my process to try and help the next guy:
https://www.youtube.com/watch?v=IvHvOyFNQvQ
johnpainter is offline
post #26 of 59 Old 04-18-2014, 09:56 PM
RikRotorhead
Just bumping this thread because I want to do this mod when you have time Jeff. (hint for your help lol)
I have the ECM and throttle body. I need to put together the rest of the parts.
Great write up. Your Jeep runs great, I'm a witness.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #27 of 59 Old 05-05-2014, 05:11 PM
bpounds
bpounds's Avatar
John, I have this kit ordered and I've been referring to your video. Thanks for taking the time to shoot that. I'm wondering about the air cleaner. Did you change that to something else? How did you tie the crankcase breather line into the intake?
Jbolty, thanks for your thread. Hoping to get something ordered for the air cleaner so it will be here when I start the install. I guess I don't want to go with the junkyard style.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #28 of 59 Old 05-06-2014, 03:32 PM
johnpainter
You know, I ended up getting that generic 10" open air cleaner thinking that I would replace it, but I ended up keeping it. The Jeep passed NJ state inspection with it, and the crankcase breather goes into the base of the open unit. There's a hole there designed for it. Someday if something better comes along I'll swap it out, but it's really been fine as it is.
post #29 of 59 Old 05-06-2014, 04:50 PM
bpounds
bpounds's Avatar
Thanks for the reply, John. Last night I ordered a Moroso 8.5". It is the same as one of the ones Howell recommends, but I got a black powder coated model instead of the chrome. Supposed to come with the connector for crankcase vent line. Cost about $75. A bit expensive, but at this point what's an extra C note or two.
Bill
bpounds is offline
post #30 of 59 Old 05-07-2014, 10:20 PM
gtg413i
2003 WJ
Originally Posted by jbolty View Post
Doubt it. Those plugs a pre obd-1, as far as I know.
I don't think I have ever heard or read about anyone plugging anything into those. Dealer only maybe?
Check out this link for the diagnostics. http://home.sprynet.com/~dale02/list.htm
One thing i think is missing is pics of the vaccuum hose connections. The install instructions arent too clear. Subscribed.
Brian's Black Betty Build:
gtg413i is offline
finally.... my 95 with 4.3 completed captainauti YJ Wrangler Technical Forum 12 01-06-2011 08:04 PM
Lift Finally Completed!! Terrantula TJ Wrangler Technical Forum 13 03-27-2008 09:09 AM
Completed Clutch Install/Replacement cdrymalla TJ Wrangler Technical Forum 2 01-03-2008 06:56 AM
Just completed the MML install Rocky529 TJ Wrangler Technical Forum 5 06-22-2005 04:30 PM
FInally completed my 4.5" ruby superflex lift thekrutchmaster TJ Wrangler Technical Forum 5 01-10-2005 09:20 AM
