#1 | |
Filling Fuel Tank Problems
Originally Posted by 4wheel4real
I have been having a weird issue with my gas tank (I think). Now it does have a dent in it but it has been having this issue before the dent was there. When ever I go to fill up at the pump the pump handle always pops as if its full and I know its not..it will do this on a half tank of gas..it's really starting to get annoying because I can't tell when I'm actually getting full or not. Like on Sunday I spilled gas out of it because I have no idea when it's getting full, I have to squeeze the handle at a certain point to get it to flow right. If I pull the handle all the way up and push the medal clip down to hold it there it just stops pumping.. Has anyone else had issues like this? How does the pump know when I'm full? RE: filling fuel tank problem I also just started having the same issues while "TRYING" to fill my tank. It's a '90 wrangler-4.2 & I never had this problem until the past 2 months. I've pulled the nozzle up/down, side to side, very slow squeeze of the trigger and after about 10 mins. of it just acting like it's full (gas pouring out of filler pipe) I normally give up with just 5-10 gallons. (if I'm lucky). I looked for the vent tube/breather, what I saw with out dropping the tank was a hose that ran down & "T'ed" into a block that was mounted to the rear axle..?? Is this the fuel tank vent? OR is there somewhere else I need to look for this vent? Thanks for ANY other help!! ![]()
#2 |
Got my eye on you.....
Unfortunatly, aside from doing a TJ filler tub conversion, this is kinda normal for the YJ. Both of mine have done it.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#3 |
yeah my yj does it alot of the time...it sucks lol
My Dually CJ Restoration http://www.jeepforum.com/forum/f8/cj5-restoration-thread-632654/ ../|,[____], .i.---L-[]IIII[]- .=..^.-.-===- ()_) ()_)-o-)_) KB3RDF ..... Yellow Jeep Club Member # 513 |
#4 |
Mine does this as well. If I pull the nozzle out of the filler tube about an inch or two from all they way in and it helps some.
My Build Up 95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear Down the line a bit...engine swap, the list goes on. |
#5 | |
89' YJ Larado 4.0L,AX15 01' Grand Cherokee 4.0L Check my Gallery for pics. My Rebuild Thread Take a minute and fill out your profile, Please |
#6 |
Mine does that "maybe I'm full, maybe I'm not crap all the time. The best is when, after you cajole the damn nozzle to the right position, the tank really getting to be full, and the damn thing blows a quart or so gas back at you without "tripping" the handle safety catch. Real thrilling!!!!!!Makes the ladies at the Quik-Fill soil themselves (I don't know if soiling occurs from fear...or laughing at the idiot with the gas up his arm again!!!)
#7 |
Why am I here?
Fellas, what you are talking about is fluid dynamics. I have a knowledge of this as I am in the business of measuring petroleum products. I also helped design the metering valve on certain types of gas pumps back when I was shortly out of technical school.
The gas tank has a filler tube and a breather tube. The breather tube is smaller than the filler tube as it only has to vent fumes. BUT, the passageway at the filler neck (where you stick the gas nozzle) for the vent tube is quite a bit smaller than the filler tube hole where you stick the nozzle in. The filler nozzle works on back pressure. When the balance of vent and filler tube equals the right pressure within the gas tank, the nozzle senses it and cuts off. The problem is that we are dealing with old technology on our gas tanks. The nozzles today are calibrated to work with newer vent systems. Our old antiquated venting wasn't designed well in the first place. If you want to stop the hassle, and have it work better without spillage of the "liquid gold", run the pump on a slow setting. It lets the gas flow more evenly, the pressure equalizes better, and you may even get a drop or two for free as certain pumps don't meter as well at slow speeds. HTH ![]() |
#8 | |
#9 |
Junior Member
i have that problem too if i try to pump fast. when pumpin fast it stops at 12-13 gallons, but it holds 18 so u just gotta pump slower.
#10 |
BUILT. NOT BOUGHT.
all this talk about pumping slower and pumping faster, sticking it in a little and tot he left, pulling it out except for a couple inches, liquid gold getting all over yourself, excessive spillage... what were we talking about again?
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#11 |
my tj does this, it will stop filling after like 10 gallons then i have to click it all the way to 21 gallons which is where it should be. i will sit there for literally 20 min pumping gas, cars will come and go and ill be standing there pumping gas still. i freakin hate that so much.
-Andrew Low Output 4 Cylinder Jeep Club member #59 [QUOTE=Grewe02]No such thing. Eat **** and die.[/QUOTE] lifted with some extra's ......sold |
#12 |
If you want to stop the hassle, and have it work better without spillage of the "liquid gold", run the pump on a slow setting. It lets the gas flow more evenly, the pressure equalizes better, and you may even get a drop or two for free as certain pumps don't meter as well at slow speeds. HTH [/QUOTE]RE: Zeus87gn... I can understand what you're saying about old & new style systems however, I've not had this problem before until just the past few months! Believe me I have tried different angles, depths & nozzle trigger speeds. I've spent up to 10+ minutes doing this and only end up with 5 gal. It makes sense what you're saying but I think it's more likely to be a vent issue (hose,etc.) on the Jeep not the pump/nozzle since I've owned it a year now & it's just now doing it.. Thanks for the info... |
#13 |
Pump gas at a slower rate, will never spill over, or cut out.
#14 | |
Uhh Hello? This thing on??!!
I was just wondering how many people are actually READING Before they reply??!! I keep getting "slow down on the pump", etc. I HAVE STATED THAT I HAVE DONE EVERYTHING AT THE PUMP!!! I will check out my hoses/vent on the filler/tank like the others who have READ the thread & then gave me advice.....But Thanks for your "TIP" anyway...... ![]() |
#15 | |
Why am I here?
If they are old looking and fraying, they could be fraying on the inside, thus causing strange back pressure. You can get into you rear fender and remove the hose clamp and check it out. Have a new clamp handy as you will probably mess up the old one. HTH |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
