Figuring out a Dana 30 again - JeepForum.com
post #1 of 5 Old 04-17-2010, 06:52 PM Thread Starter
de-rat
I took out my front axle and I can't figure out what this thing on the axle is for. It had vacuum lines and electric hooked to it. Can you guys help?
de-rat is offline
post #2 of 5 Old 04-17-2010, 07:16 PM
Alfons
That unit is called a "Vacuum Motor" and is used to engage your 4wd. The passengers side axle shaft is split and when it's disengaged, the axle "free wheels" but when the vacuum motor engages the 2 pieces, it causes the whole thing to work like a normal differentiated axle, so when the front drive shaft is engaged & the split shaft is engaged, you have 4wd.
There are quite a few threads here that show the vacuum "plumbing" that you need to have it work. There are also threads that describe how to make and/or install a manual shaft engagement system - called Posi-lock.
Alfons is offline
post #3 of 5 Old 04-17-2010, 11:50 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The system is called: central axle disconnect (CAD).
Joe Dillard is offline
post #4 of 5 Old 04-18-2010, 08:38 AM
2uraven
have fun replacing the intermediate seal. funnest job ive done yet. took me less time to remove rebuild add a sye and reinstall my transfer case
2uraven is offline
post #5 of 5 Old 04-18-2010, 09:10 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
installed..... notice the fork up close in the picture, it goes over the collar you see in the dico box. the fork moves and locks the front axles together via vacuum lines when you shift the t-case into 4x4.
intermediate shaft, outter shaft, and collar all pulled out
the vacuum lines run to the t-case. it comes out on top of the NP231 right before it bolts to the tranny.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
Figuring out my Dana 30 de-rat YJ Wrangler Technical Forum 9 05-03-2011 06:37 PM
i still need help figuring this out!!! Grants99TJ TJ Wrangler Technical Forum 5 12-29-2009 01:48 PM
Need help figuring out value... kg6mti YJ Wrangler Technical Forum 6 12-22-2009 03:29 PM
Need some help figuring out exactly what I Have BondoBbad YJ Wrangler Technical Forum 10 09-19-2009 09:34 PM
figuring out what to buy?? Ricky65 TJ Wrangler Technical Forum 0 03-20-2009 07:29 AM
