FI Cherokee motor in a 87 Wrangler??? - JeepForum.com
post #1 of 7 Old 02-15-2013, 10:07 AM Thread Starter
reptilerecords
Can you put a Newer Cherokee motor in a 87 Wrangler. I am looking for a good alternative to putting a Fuel injected motor in my 87 with out the whole aftermarket kit I've been told a newer cherokee wont work without a bunch of modifications? Will a chevy venture type v6 go in a wrangler 87-91? Help what are my options please?
reptilerecords is offline
post #2 of 7 Old 02-15-2013, 10:22 AM
SeanB95YJ
unfortunately, nothing will be a direct bolt-in "plug n play" situation.... on the plus side, that leaves you open to a whole world of possibilities, all which are about the same amount of work, time & $$
4.0 Jeep
4.3 GM V6
GM V8
Ford, mopar, toyota, cummins, etc
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 7 Old 02-15-2013, 11:16 AM Thread Starter
reptilerecords
I have just heard the newer cherokee motors stick up to high as far as the power steering, alternator etc.. what would be the best Fuel injected motor to put in my 87 wrangler?
post #4 of 7 Old 02-15-2013, 11:47 AM
Que89YJ
The 91-95 4.0L mpfi would be the easiest and cheapest. Plent of them around and 5 wires to fire on the harness swap. If you are lucky enough to find one with the entire drivetrain then you are only looking at moving your mounts.
Que89YJ is offline
post #5 of 7 Old 02-15-2013, 11:49 AM
schaef89
You should research the junkyard tbi upgrade
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #6 of 7 Old 02-15-2013, 12:15 PM Thread Starter
reptilerecords
is that the wrangler 91-95 4.0L mpfi and or the cherokee?
post #7 of 7 Old 02-15-2013, 12:30 PM
Que89YJ
Yes, exactly.
Que89YJ is offline
cherokee , motor , swap , wrangler
