A few YJ ?'s - Page 2 - JeepForum.com
post #16 of 41 Old 02-28-2013, 01:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The hp30/8.8 combo is plenty strong for a set of 33's but the engine and transmission have much more reliable peers that would work better in any jeep. I'm excited to see what comes of this.
Luck Favours The Prepared
Anticanman is offline
post #17 of 41 Old 02-28-2013, 02:13 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I feel pretty good about the 8.8, I'd lean a little more towards an 8.25 though. IIRC, they accept the same axle shaft on either side, makes carrying spares a bit easier. The HP30 is a pretty solid axle...however I have a buddy in my club who's a rock-bouncing-throttle-jockey and I think he snaps a U-joint just about every time we go on a run
I'm on the hunt for a set of waggy 44's to build. I know they'll be up to the job...I tend to have a bit of a heavy foot myself.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #18 of 41 Old 02-28-2013, 02:48 PM
dillonjm
2013 WK
Why would you use an inferior axle to make carrying spare shafts easier?
The 8.8 is much stronger than the Chrysler 8.25. Granted anything can be broken but it is darn near bulletproof up to 35s if you use your head at all while wheeling.
As far as the HP30, with some upgraded shafts that have full circle clips, it holds its own with 35s as well in rigs that weigh as little as our YJs.
We can debate the difference in 44s and 30s but for my money, in a YJ, you don't gain much by swapping to a front 44. The weak point is still in the u-joint which is the same 297 joint that many run in their d30.
Start talking about higher torque/heavier rigs then we can talk about why the larger pinion and thicker tubes in the 44 are desirable, but for a YJ with stock drivetrain there's no real need.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #19 of 41 Old 02-28-2013, 02:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Ujoints and the ball joints. They're the same on both axles.
post #20 of 41 Old 02-28-2013, 03:05 PM
rd94yj
Not wanting to start any arguments but I'd defiantly consider running the 8.25 over the 8.8.
I completely trashed my 8.8 with just 33s locked.
And do that t18 swap!!! Im doing it right now with my 4.0. Be sure to do your research. It takes some time to figure out exactly what all you'll need.
94 YJ 60/14 bolt 4.0 ax15 Dana 300
88 YJ 60/14 bolt AMC 360 nv4500 np241
rd94yj is offline
post #21 of 41 Old 02-28-2013, 03:09 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
8.8 is stronger, but they're not worlds apart. Certainly not like comparing a D44 to a 60 and it's a significant upgrade from a D35. Knowing that this rig will run 33's and never anything else, I'd have every confidence that it would hold up just fine.
The real determining factor to what goes in will ultimately be cost and availability. Just found an HP30/8.25 4.10 locally that's a really nice deal if it's still available. Also have an email out about a set of waggy 44's for very cheap that would be a fun build. Cost of regear and lockers is pretty much a wash whichever way I go.
As far as the HP30, with some upgraded shafts with full circle clips it holds its own with 35s as well in rigs that weigh as little as our YJs. We can debate the difference in 44s and 30s but for my money, in a YJ, you don't gain much by swapping to a front 44. The weak point is still in the u-joint which is the same 297 joint that many run in their d30.
We'll definitely have to disagree here
http://i1139.photobucket.com/albums/...ps90d0418c.jpg
D30, 44, and 60 ring gears side by side. While the D44 is a good bit larger than the 30, it also opens up running 35 spline shafts.
Yep this is definitely going to be part of the winter build. Super deep 1st gear should remove the need for having to run a doubler. There's a T18/D300 listed locally I've been trying to get my hands on for a few weeks, the owner seems to be MIA though! :thumbsdown:
post #22 of 41 Old 02-28-2013, 03:24 PM
dillonjm
2013 WK
No hard feelings. I'm just very opinionated on the "30/44 in the front of a YJ issue"
For a YJ on 35's or smaller, I'm saying it doesn't matter. The R&P are not the weak point in either axle (44/30). The u-joints are, which are the same if you're not using the stock YJ 260 joints.
If we start talking 37's, neither axle is up to it without significant upgrades. If you're trying to upgrade a 44, which you talk about by saying it opens up 35 spline shafts, you might as well just go for a 60 since the cost/benefit isn't worth it unless you REALLY want to run 37's and don't want to drag the differential, but even then you'll still spend more on the 44 than it would have cost to put in a 60.
That's all the point I was trying to make.
Regarding the 8.25, I'm trying to find some COT/MOT #'s for it and I'm coming up empty right now, but IIRC its lower than the 44 and the 8.8 is quite a bit more than the 44, in fact, its closer to the semi-float 60 than the 44:
COT: Continuous output torque rating
MOT: Maximum output torque rating
Dana 35 rear axle COT: 870 MOT: 3480
Dana 44 rear axle COT: 1100 MOT: 4460
Ford 8.8 31spline COT: 1360 MOT: 5100
Dana60 semifloat COT: 1500 MOT: 5500
For 33's though, you're right, it probably doesn't matter, both the 8.25 and the 8.8 can hold up to 33's very easily.. However, going with an 8.25 because "spares are easier to carry" wouldn't be the reason I went with it. On 33's with an 8.8 there is no reason to carry spare shafts.
Cost and availability might be, as you stated, a very good reason to go with one over the other, however.
dillonjm is offline
post #23 of 41 Old 02-28-2013, 03:35 PM
dillonjm
2013 WK
The 8.25 is weaker than the 8.8, this is invalid.
dillonjm is offline
post #24 of 41 Old 02-28-2013, 03:43 PM
Ripper3494
I throw my vote in for waggy 44 in the front. On 33s and a 4 cyl I bent axle tubes on my 30. I have yet to actually break anything on my front 44 (knock on wood) with well over 3 times the engine and 37s
Probably sent from under my broken heep
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #25 of 41 Old 02-28-2013, 03:44 PM
dillonjm
2013 WK
I thought you broke a shaft a few weeks ago? Driver side if I recall correctly.
dillonjm is offline
post #26 of 41 Old 02-28-2013, 03:51 PM
Ripper3494
You caught me there's actually a story for that one.
I had no rear driveshaft and i had my passenger side hub unlocked and was using torque steer to turn the front wheels since I had no pitman arm.
Standing on the brakes and gas in 1 wheel drive low with a 6.0 is bad. Also doesn't help it was already turned at full lock.
I'll re make my statement, I have never broken my front 44 anywhere except in my driveway lol
build thread:
RC vs BDS
post #27 of 41 Old 02-28-2013, 03:52 PM
dillonjm
2013 WK
Had me thinking I was crazy(ier than normal).
dillonjm is offline
post #28 of 41 Old 02-28-2013, 03:54 PM
Ripper3494
Nope you were right, I try not to think about the times when I do **** like that lol
build thread:
RC vs BDS
post #29 of 41 Old 02-28-2013, 03:55 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Gotcha. I appreciate the tech info on the 8.8, helps put things into measurable perspective. The only real downside to the 8.8 is the offset pinion. Spare shafts aside it is known that at full droop and compression it can cause some significant binding of the driveshaft.
Ultimately it will come down to what it always comes down to, price and availability. I have a local guy now down to $400 for a matching set HP30/8.25 with 4.10's from a '95 XJ. Since this is definitely a budget minded build, unlike my JK , it's likely this set will find a home under the YJ. I can run them for now, then decide if I'm going to build them or work on another set and sell them later.
post #30 of 41 Old 02-28-2013, 03:59 PM
dillonjm
2013 WK
Sounds like you've found a good budget combo to run there, a little cutting and welding and you should be good to go!
For those reading that are contemplating an 8.8 swap, a SYE/double cardan shaft with a properly set pinion angle solves that binding issue, which is only really an issue and lift sizes that require a SYE anyway.
dillonjm is offline
