A few YJ ?'s - JeepForum.com
post #1 of 41 Old 10-24-2012, 04:37 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
A few YJ ?'s
What's up old timers? I'm looking at getting into a YJ in the near future so naturally I had a few questions. I'm sure a lot of this could be found by searching, but frankly I'm lazy, and since I'll be web wheeling with y'all in the future this can double as an intro post.
So I've got a pretty built JK that doesn't see the road much any more, mostly due to the comp stickies I'm running. Swapping some one tons in, linking the rear, fuel cell, and atlas are all happening over the next few months while we're covered in snow....moral of the story is the JK is pretty much going to be trailered and beat like it owes me money. Thus the quest for another jeep. Something that will function as a moderate trail rig and something fun to drive around town.
I'll be looking to pick up something fairly low miles and low rust, preferably something that hasnt been wheeled and modified. Tall order I know, mostly focusing my search down south.
Now for the Q&A
Q1: What are the WMS - WMS dimensions on the stock axles?
I'm planning on taking the D44's out of my JK and putting them under the YJ. They're already geared to 4.88, lockers, chromo shafts, ect, I can still use the bead locks that I currently run. Pretty much just have to fab a drag link and weld on some spring over plates. The only concern I have is the JK's are 65" axles...worried they'll be a bit too wide.
Q2: I'm looking to run 33x12.50's, probably just some MT/R K's. A spring over job when I swap my axles will net me just over 3" of lift. Should that be sufficient to clear the tires with good articulation? Should I look at some lifted springs also, maybe just add a bit of a body lift too?
Q3: Spring rates. I'm not planning on adding a ton of sprung weight, basically just a solid flat belly skid, some boat side sliders, and 1310 driveshafts, maybe some rear corners. My gut reaction is to go with a softer spring. Outside of street driving, going to be a lot of fire roads and light to moderate rock crawling. Pretty much all low speed stuff. Thoughts?
Q4: Any thoughts on the general build plan? Think of anything I'm leaving out? Hate my accent?
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #2 of 41 Old 10-24-2012, 04:43 PM
mrmark
http://www.jeepforum.com/forum/f12/y...-specs-563403/
I believe SOA gives 5 1/2" so 33's may be small but will fit if you only get 3"
As for springs ask Canman that's his area of expertise.
Hate the Pats and the accent
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #3 of 41 Old 10-24-2012, 04:50 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Cool, thanks for the link. Didn't really think about the spring plate moving from the bottom to the top, just the width of the axle tube, 5 1/2" makes more sense.
I see they have vehicle width at 66" but no info on axle width. Any ideas?
I'm actually a Carolina boy, just moved up to Boston so I could make some MF'ing money!!!
post #4 of 41 Old 10-24-2012, 05:19 PM
mrdeath2000
Dana 30 up front is 60.5", I was just looking at some 8.8 info where it referenced it.
D30 - 60.5"
8.8 - 59.25" (when looking at the normal explorer axles)
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #5 of 41 Old 10-24-2012, 08:24 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
D30 - 60.5"
Cool, thanks to the info. Looks like the JK axles will work fine, probably not with my current wheels though, 3.5" backspace and I'll we way too far outside the fenders. I'll add them to the "**** to sell" list and pick up some cheap steelies.
post #6 of 41 Old 10-24-2012, 08:49 PM
NHfireLJ
NHfireLJ's Avatar
If you are looking only to run 33's SOA is gonna be alot of extra room as already stated... and alot of $$, especially when you take steering correction with a high steer set up...
and as stated SOA with stock springs is gonna be 5.5" lift
For your desired driving and wheeling around here, (I'm just North of you) and the 33's you can go with a 1" BL and quality 2" springs like OME, and some TJ flares (trim the tub a bit). you can also add some 5/8" shackles too...
Or 4" springs with no trimming, like RE springs. Stay away from RC...
Good luck...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #7 of 41 Old 10-24-2012, 09:37 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Cool, thanks for the input. Looks like the 2" spring and BL or 4" setup will be the way to go. Probably just end up going with whats most cost effective, already put enough dough into the JK. I was looking at the OME 2" spring and shock setup, anyone have anything bad to say about their shocks? haven't been real popular in the JK world.
Definitely going to beef up the shackle mounts right off the bat too, seems like every time I wheel with YJ's someone breaks a mount Been thinking a Z shackle/revolver setup if I'm going to replace them all anyway. With this setup recommend going with a mid-spring rate?
What clubs do you run with? Baystate here.
post #8 of 41 Old 10-24-2012, 09:41 PM
dillonjm
2013 WK
OME is well thought of in this part of the Jeep world, especially their leaf springs.
Many who go that route prefer the HD springs.
Other good spring options are BDS and RE. Can get a good ride and very good flex/peformance out of any of these three brands.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #9 of 41 Old 10-24-2012, 09:42 PM
lestes94
I think I fit the criteria for the YJ you want: Fun to drive, no rust, new motor, in the south, and not heavily modified! And possibly for sale here shortly.
'94 YJ: 4.0L HO fi, 5-speed AX-15, Daystar 1.25" shackles, 17" JK wheels, lined tub, custom paint, Bestop Supertop, etc..
'88 YJ: 4.2L carb, 5-speed, stock everything. Banana-ish yellow. hard top. 26,XXX original miles.
lestes94 is offline
post #10 of 41 Old 10-24-2012, 09:53 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
PM me some details. I'll be down in NC for a few weeks, about December 20th to January 10th. I can pull an empty trailer if need be.
post #11 of 41 Old 10-24-2012, 10:25 PM
lestes94
Well, I'm in Arkansas.
lestes94 is offline
post #12 of 41 Old 10-24-2012, 10:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
With whatever springs you go with, remember that the diameter of the Dana 44's is larger than that of the Yj stock axles so spring under or over will give you less or more lift respectively. Also, most aftermarket perches are not flush with the axle tube so it will accentuate this perk. Build wisely! I can't wait to see how you figure out the steering to adapt it to the Yj.
Luck Favours The Prepared
Anticanman is offline
post #13 of 41 Old 10-24-2012, 11:29 PM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Hell of a ride, Googled Charlotte to Little Rock...about 800 miles. Right Jeep for the right price and I'll come get it, need some details.
Good point. D44 is 3" tube...maybe 3 1/8" (?) and the D30 is what, 2 5/8"? Best bet is probably to go with a 4" spring, should net enough to clear the 33's. Should have also mentioned I'll be trying to squeeze in some 12" travel shocks. Shouldn't have to french them in to the frame with the wider axles....we'll see.
I'm a bit out of my element trying to visualize all this. Looking forward to getting it in front of me and up on some jack stands. Far from anything ground breaking in terms of the build plans, but it should be fun anyway.
Not 100% sure on how the steering setup will go yet. I was hoping to leave the tie rod as is, then run a drop pitman arm and build a drag link out of DOM with one ton ends. That said, I have only a basic understanding of how the stock setup works and if there is even room to follow my plan.
post #14 of 41 Old 02-28-2013, 10:32 AM Thread Starter
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Figured I'd bump this thread since I finally found what I'm looking for:
Added another to the stable today. '88 4.2/BA-10 with 98,000 on the clock, almost no rust for a new england vehicle.
Immediate plans are a 2.5" spring lift and 33's on steelies. Once the JK is rolling again I'm going to do a T18/D300 swap and either build a set of 44's or there's always sets of HP30/8.8's floating around. We'll see what I can find on the cheap!
I'm director of trails for one of my clubs where most guys are on 33's or 35's, lets just say my JK has outgrown that scene a bit! This will be the mild/moderate rig
Feeling like a bit of an *** clown for selling the 44's from my JK
post #15 of 41 Old 02-28-2013, 10:54 AM
HaskiE
HaskiE's Avatar
Hell yeah! congrats on the Jeep!
#theneverendingaxe
HaskiE is offline
