Few YJ 4.0 Turbo picts - Page 4 - JeepForum.com
post #46 of 112 Old 01-26-2009, 07:40 PM
01blackws6
Vids not working for me
1994 YJ 2.5l. RUST BUCKET!
1" daystar BL.
01blackws6 is offline
post #47 of 112 Old 01-26-2009, 07:44 PM Thread Starter
scrapinrocks
should work now
scrapinrocks is offline
post #48 of 112 Old 01-26-2009, 07:56 PM
evilwaysYJ
that is awesome! sweet build you have there, i was thinking of doing a turbo disel out of a 2wd comanchee but havent found one. so what did you end up with for HP and tq totals?
evilwaysYJ is offline
post #49 of 112 Old 01-26-2009, 08:17 PM Thread Starter
scrapinrocks
202 hp and 265 lb/tq
post #50 of 112 Old 01-26-2009, 08:40 PM
tazme695
Im looking to do one on a 4 banger! Rounding up parts!!! New to forum been reading it for a month love it! I should fit right in! I will upload my pics asap want to finish my body work kinda hard cause i cant stop driving it!!
tazme695 is offline
post #51 of 112 Old 01-26-2009, 08:41 PM
yjcrawlr
I have a turbo out of a early 90 mercedes diesel sitting on the shelf in my garage. Does anyone know what the compression of a stock 4.0 is? I was going to put it on my 196 4cyl scout but it looks about the same size as that one. Hmmm.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #52 of 112 Old 01-26-2009, 08:55 PM
Obie95Sahara
I would love to do this, I have a turbo from an RX7 laying around thats just dying to be used
Obie95Sahara is offline
post #53 of 112 Old 01-26-2009, 09:07 PM
Ron_K
The standard '87 YJ engine was the 2.5L inline-four 1bbl carburetor, while the alternative was the 4.2L six-cylinder 2bbl carb held over from CJs gone by.
In 1988, the four-cylinder went throttle body injection, and both engines increased their compression ratios to 9.2:1. The following year, the 4.2L went standard for the Laredo.
For 1991, the Power Tech 4.0L was dropped in where the 4.2L used to be; the new 242ci multiport fuel-injected mill made 180 hp at 4,750 rpm and 220 lb-ft of torque at 4,000 rpm, with a compression ratio of 8.8:1 and bore-and-stroke of 3.88x3.41.
here's some info that should help
"You're only Limited by Your Own mind."
91 YJ, rear body armor with rock rails and TJ filler conversion. LED Tail lights. 33 x 15.50 x 15 SS TSL SX's on black steelies. Home made Bumpers and swing out tire carrier. MileMarker H9000 Winch, H/T & Bikini Top, full doors & half doors. ~RIP~ C.D.K. 11-11-08 (miss you baby)
NTM 1989 XJ 2 Door Cherokee Sport, I6/auto/Swingout carrier, Custom Stereo system that makes my heart skip a beat.. IT'S My New DD and da^% happy to say I finally own one ;)
Ron_K is offline
post #54 of 112 Old 01-26-2009, 09:35 PM
yjcrawlr
Thanks ron, not bad compression for turbo chargin. Hmmm.
yjcrawlr is offline
post #55 of 112 Old 01-26-2009, 09:56 PM
Ron_K
Definitely not-
I run 9.2:1 in my turbo bike no IC only C16 and H2OInjection
Ron_K is offline
post #56 of 112 Old 01-26-2009, 10:01 PM
yjcrawlr
What is the turbo bike? busa?
yjcrawlr is offline
post #57 of 112 Old 01-26-2009, 10:55 PM
provinT13
Did you run a intercooler?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #58 of 112 Old 01-26-2009, 11:36 PM
themonkeyman
1987 YJ Wrangler
Yes, the comp ratio is pretty good, but I hear the stock cast pistons are only capable of about 7-8psi before they start melting
Forged pistons would be sick, but require a little more then "bolt-on"
themonkeyman is offline
post #59 of 112 Old 01-27-2009, 07:26 AM Thread Starter
scrapinrocks
no I did not use an intercooler. space is tight and an IC will not to anything on the trail. I will be running a water/meth injection setup. that ws when I do go into boost I know I will have a nice cold dense charge
post #60 of 112 Old 01-27-2009, 09:26 AM Thread Starter
scrapinrocks
Doorless, with top - picts and impressions jeepers3 JK Wrangler Technical Forum 25 03-16-2007 03:37 PM
what do you think of this? picts. lucasinpsj TJ Wrangler Technical Forum 19 10-11-2005 11:30 PM
White on red? Any picts? Skool4life? TJ Wrangler Technical Forum 6 04-02-2003 03:04 PM
rubicon kit installed. picts. CETROV TJ Wrangler Technical Forum 6 08-23-2002 10:26 AM
playing in the mud today- picts. CETROV TJ Wrangler Technical Forum 2 02-04-2002 11:49 PM
