Few YJ 4.0 Turbo picts - JeepForum.com
post #1 of 112 Old 12-31-2008, 11:25 AM Thread Starter
scrapinrocks
Few YJ 4.0 Turbo picts- dyno vids added
Finally finishing up this little project with a buddy of mine. Will be finishing the exhaust Friday night. I drove it the other night and people were confused, noises like that should not be coming from a Jeep. Ill get some more picts up later. Still have to put the heat shield I made for the battery in and put the vent in the hood. Not running an intercooler, instead I will be running a water/meth injection system. Fuel was done with a booster pump and 12:1 FMU. I moved the intake air temp to the charge pipe to help combat the computer pulling timing. So far the thing pulls pretty good. only running 7 PSI not, will be up to 12psi after the water/meth in is.
scrapinrocks is offline
post #2 of 112 Old 12-31-2008, 11:28 AM
themonkeyman
1987 YJ Wrangler
Click free, looks pretty intense. What comp ratio pistons you running?
themonkeyman is offline
post #3 of 112 Old 12-31-2008, 11:38 AM Thread Starter
scrapinrocks
thanks for gettin em up man!! stock internals for now. comp ratio is 8.8:1 which is pretty good for boost. when it dies I will build the motor, maybe do a stroker with the turbo. I'll post up the dyno numbers when I get them, hopefully next week or the week after
post #4 of 112 Old 12-31-2008, 11:41 AM
MLJeeper
MLJeeper's Avatar
Very cool
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 112 Old 12-31-2008, 12:04 PM
BeerJ
Nice! What kit is that?
Originally Posted by toates89 View Post
Now i am in love with beer. I have had around 100 beers.
BeerJ is offline
post #6 of 112 Old 12-31-2008, 12:06 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Looks like a custom job.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 112 Old 12-31-2008, 01:12 PM
alfredopr
nice nice it must intercooler ?
alfredopr is offline
post #8 of 112 Old 12-31-2008, 02:11 PM
BeerJ
huh?......
BeerJ is offline
post #9 of 112 Old 12-31-2008, 02:33 PM
blue1989yj
blue1989yj's Avatar
Nice looking job. Where in CT are you?
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #10 of 112 Old 12-31-2008, 02:38 PM
Jeeeeeeeeeeeeep
Nice what are you using for a computer and fuel management?
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #11 of 112 Old 12-31-2008, 02:41 PM
242much
2009 JK Wrangler
you just run an exhaust pipe underneath the motor to put the turbo on that side? and no air to water intercooler? there's a company out of australia that makes barrel shaped straight air to water intercoolers, complete with pump, reservoir and heat exchanger. a little bit of google should find them pretty easy.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #12 of 112 Old 12-31-2008, 07:49 PM
bob082484
Very cool setup. Let us know what kind engine management you chose to run. Was goin to turbo mine but decided to go with an eaton m90 instead.
bob082484 is offline
post #13 of 112 Old 12-31-2008, 10:17 PM
OneCleanYj
Looks good! I've been debating whether or not to start accumulating parts to build my own turbo kit. Up in the air about it still...
If the FMU doesn't work out look into the Split Second controller. A member over on 4Bangerjp.com has had very good luck with his, and seems to be the answer to the ECU's closed-loop system. It's pricey, but again if it doesn't work out it's something to look into http://www.splitsec.com/
Dolan
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #14 of 112 Old 12-31-2008, 10:43 PM
muddbog
Nice set up! I like supercharged better... no lag!
1991 YJ 2.5l
, ___
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
muddbog is offline
post #15 of 112 Old 01-01-2009, 09:23 PM Thread Starter
scrapinrocks
My turbo is sized really good for the motor, I would say that at normal crusing speed there is no lag at all, and yes it is a home made kit. I was going to intercool it but after thinking about it I opted not to because an intercooler will just take up space and moving a 2 mph on the trail, the IC will not do a thing. Instead I will be running a water/meth injection setup. That way everytime i hit enough boost i will be a nice cool dense air charge. Im running 7psi now, the water/meth will come on a 4psi. no chips or computer mods. just used a 12:1 FMU and a booster pump. jeep pulls really hard actaully and is really nice to drive. Im located in central CT, Newington to be exact. i'll get the numbers up as soon as i get to the dyno
Doorless, with top - picts and impressions jeepers3 JK Wrangler Technical Forum 25 03-16-2007 02:37 PM
what do you think of this? picts. lucasinpsj TJ Wrangler Technical Forum 19 10-11-2005 10:30 PM
White on red? Any picts? Skool4life? TJ Wrangler Technical Forum 6 04-02-2003 02:04 PM
rubicon kit installed. picts. CETROV TJ Wrangler Technical Forum 6 08-23-2002 09:26 AM
playing in the mud today- picts. CETROV TJ Wrangler Technical Forum 2 02-04-2002 10:49 PM
