Few questions about shackles - JeepForum.com
post #1 of 6 Old 02-05-2006, 10:38 PM Thread Starter
Ryanjeeper
What is the stock shackle length? What is the longest length for a shackle that would be good for a lift? Can you run 31's with no lift? What length shackles would you need for 32's or 33's? I know this is a lot of questions but it would be great for some answers!
Thanks
Ryan
1990 YJ
Rubicon Express 2.5" Standard Lift
32x11.50 Lemans A/T
Ryanjeeper is offline
post #2 of 6 Old 02-05-2006, 10:44 PM
rbn1357
rbn1357's Avatar
Shackles give a 1/2" of lift for every inch added to the stock length. And I think Stock is 4". I have 2" shackle lift (8" shackle). Would never do it again. They look fugly ,alter steering a bit, worsen ride, and flatten springs. Stay away from shackles longer then 1" 1/4 lift.
People on here get boomerang shackles for the rear to help with the springs.
rbn1357 is offline
post #3 of 6 Old 02-05-2006, 10:47 PM Thread Starter
Ryanjeeper
so what tires will 1.25" shackles run?
1990 YJ
32x11.50 Lemans A/T
post #4 of 6 Old 02-05-2006, 11:01 PM
rbn1357
rbn1357's Avatar
When I was just running the 2" shackles and 31"s tires I had 2" gap between the tires and the fender. Could try to run 31"s with the smaller lift but might look stupid. Could also attach TJ fenders. It provides more clearance and might do the job.
rbn1357 is offline
post #5 of 6 Old 02-05-2006, 11:05 PM
rbn1357
rbn1357's Avatar
Here's what I would do if I were you since you are most likely in highschool like me (saw profile). I bought longer shackles and a body lift. This route provides no real benefit. But later on I will try to replace both with a 4" RE lift.
It will look the best and flex way more than I have now. Save your money for the lift.
rbn1357 is offline
post #6 of 6 Old 02-05-2006, 11:27 PM
Ichytriggrfingr
Ichytriggrfingr's Avatar
I run 31's with a shackle lift, I think I have 1.5" of lift. I didnt really accurately measure before i installed, but I can let you know tomorrow what the current measure is. I don't have any rubbing, and I think the end results are pretty good. I thin k I put it on before the tires, but really don't remember, its been a few years. The main point of improvement was the zerk fittings and new bushings. Before that, every bump sounded like I had dropped the Jeep off a cliff. Now it just sounds like falling off a building.
Matt
Ichytriggrfingr is offline
Bought a yj with shackles, questions... yjJeff YJ Wrangler Technical Forum 5 04-05-2009 04:29 PM
Questions on how to order MORE Shackles YJames90 YJ Wrangler Technical Forum 5 04-28-2008 08:13 PM
shackles...a few questions Tim3852 YJ Wrangler Technical Forum 6 03-05-2007 10:29 PM
Lift kit install---shackles questions pezley YJ Wrangler Technical Forum 10 03-31-2006 10:41 AM
Questions on shackles and winches. yj@vt YJ Wrangler Technical Forum 3 03-19-2002 12:32 PM
