few questions... - JeepForum.com
post #1 of 5 Old 08-26-2011, 05:17 PM Thread Starter
csrcn2
few questions...
89 yj 4.2 she was leaking oil out of the oil filler cap and base of the valve cover so I bought a new gasket and replaced the old one, cleaned up the valve cover and sealed her up nice. Even after this I still have leakage out of the new filler cap. Oil pressure. Runs up to 70 on the gauge at times. And ideas?
csrcn2 is offline
post #2 of 5 Old 08-26-2011, 05:24 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Have you checked your pcv line to be sure it is clear?
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 5 Old 08-26-2011, 05:52 PM
clarkjdg
clarkjdg's Avatar
I had the same problem on the filler cap I just took a piece of thin paper gasket material cut it out to match the cap and it took care of mine, but I didn't get a new cap just did it to my old one.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #4 of 5 Old 08-26-2011, 08:21 PM
Quail
You are probably getting oil blow-by, If you are running your stock carb and air filter you probably have it in your air cleaner as well,
Check your pcv valve, if it is good then there are some neat home made oil collector ideas around the web that will help you squeeze quite a few more miles out of your 258 before you have to rebuild.
Quail is offline
post #5 of 5 Old 08-26-2011, 10:23 PM Thread Starter
csrcn2
Well I'm running it nuttered and with a motorcraft 2150... would oil blow by cause any performance issues?
csrcn2 is offline
