a few more questions - JeepForum.com
post #1 of 6 Old 07-12-2006, 09:47 AM Thread Starter
NYSCARLETKNIGHT
when taking off my exhaust we broke what i believe are called the studs on the exhaust manifold, is there anything i can do about this or am i gonna have to run no exhaust for a while?
my other question is that my alternator is f'ed up it won't even turn, my question is if i drive during the day and i don't run the radio and i charge my battery the whole time i'm not driving, how far do you think the jeep will make it with the messed up alternator. I only ask because i have some errands to run today and i don't know if i will be able to pick up a new one.
92 YJ
4" Rubicon Express suspension lift
Boomerang Shackle Lift
SYE with CV shaft
NYSCARLETKNIGHT is offline
post #2 of 6 Old 07-12-2006, 09:51 AM
Jacked93
Odds are you won't make it very far. I wouldn't chance it. And if the alternator is seized... isn't your belt being torn up?
Jacked93 is offline
post #3 of 6 Old 07-12-2006, 09:53 AM
Leroux
Leroux's Avatar
Is the stud broke off on the engine or the the manifold itself? I dont think its really an options to run with no manifold. 6 or 4 cyl?
If you have a fully charged battery, I would guess you could go maybe 15 minutes??? but thats a big maybe.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #4 of 6 Old 07-12-2006, 09:54 AM
wraithyjeep
wraithyjeep's Avatar
drill out the studs and drill a 3/8 hole all the way through and then use stainless steel bolts, with the nuts on the top side.
running on battery only hmmm my guess not long 15 minutes maybe. before she will start to miss fire and die.
Silver Rubi JK unlimited.
89 YJ, 4.2, 5 speed, 2" lift, 235 75 r 15 M/T. CRT's HEI, MC2150 1.08, OBA, 120V inverter. removable Light bar, 10 hella lamps, trail rack w/ jerry cans, champion winch, high lift jack, C.B., lined tub. H4 Conversion headlamps, reveiw mirror w map lights. royal blue with matching trailer.
wraithyjeep is offline
post #5 of 6 Old 07-12-2006, 09:55 AM
Jacked93
I agree... it's not an option to run without a manifold. That is not a good idea at all.
Jacked93 is offline
post #6 of 6 Old 07-12-2006, 09:55 AM Thread Starter
NYSCARLETKNIGHT
haha i will have a manifold, but nothing after it. I think i'm gonna do what the one guy said about the bolts, thanks a lot fellas!
92 YJ
SYE with CV shaft
8.8 Questions mideerhunter YJ Wrangler Technical Forum 20 09-10-2008 05:48 PM
CAI Questions KevinR TJ Wrangler Technical Forum 2 08-17-2008 08:41 AM
K&n Questions! mideerhunter YJ Wrangler Technical Forum 1 08-10-2008 09:17 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 04:34 PM
Top questions. Macabre YJ Wrangler Technical Forum 7 06-03-2004 08:19 AM
