A few easy upgrades, part two - JeepForum.com
post #1 of 11 Old 04-23-2012, 07:27 PM Thread Starter
pasinbuy
Here is part one, http://www.jeepforum.com/forum/f12/f...my-yj-1357433/ since I cannot figure out how to reduce the pictures I will just make a new thread. The first thread shows a easy way to keep water from pooling on your soft top and to keep your soft top from flapping in the wind. And the second tip in the first thread is how to makes and install a $7.00 hand shifter for FI Yjs. The sink clip is the really cool part.
On this thread I will show what you can do with your old soft top to make it last a little longer after the threads pull out on the rear corners and the mesh that I used to keep honest hands out of my Jeep when parked and as a side note keep my dog from falling out accidentally.
1st and 2nd Picture is my garage. I built my house about four years ago and completed it with a 25 x 46 garage with two large doors. The 12' 3" ceiling height allows me to have a lift.
Yes, I am bragging a bit. But darn do I like it. This is the garage that I would dream about as a kid.
3rd Picture is the screen that I picked up at Home Depot for about $15.00. I started by wrapping the screen around the roll bar behind the driver seat. I then tie strapped the screen to the roll bar. Next I pulled the screen around not too hard around the other four roll bar posts. tie strapping as I went along. The end fit was pretty good with a little bit of easy cutting using a razor blade. I had allot of comments from people some asking where I bought the setup. When summer comes I will have to take it down due to the extreme Florida heat but until then this works nice.
4th Picture shows the screen and my dog Rocky. I have a another top for just above the seats but it does not give enough sun protection. At the beginning of winter the threads on the corners of my top came undone. This seems to be where the soft tops start to come apart. So I rolled up the tops corner and tie strapped it. I had no intention of using the windows for the winter anyway.
5th picture is everything completed.
I just made a new sun top for my rig for free. I will be pulling it soon to run AC, but I will keep the old top and re install it next winter.
Martin
Jeep on Lift.jpg   Jeep garage lift no jeep.jpg   Jeep screen and top corner.jpg   Jeep screen with rocky.jpg   Jeep back screen and top.jpg
pasinbuy is offline
post #2 of 11 Old 04-24-2012, 09:00 AM Thread Starter
pasinbuy
Bump
pasinbuy is offline
post #3 of 11 Old 04-24-2012, 09:48 AM
giggityjeeper
not for me, looks tacky, but hey....
I bought the CRES system from Smitty for 60 bucks, dows the same thing, straps on the bar and looks way cleaner.....
no zap straps etc....
your shop and hoist on the other hand..... I will take that
anyhow your rig
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 11 Old 04-24-2012, 11:31 AM Thread Starter
pasinbuy
anyhow your rig
I was worried that it would look tacky when I put it together. But to be honest it does not look tacky. I have had allot of people compliment me on it, and be surprised that I made it myself.
The tie straps really do not show that much in real life.
Where I tie strapped the ripped top, next year before I re install the top I will cut down on the corner folds by trimming the corners up.
pasinbuy is offline
post #5 of 11 Old 04-24-2012, 03:57 PM
40dog
looks good for the dog. Not a bad idea. great shop.
40dog is offline
post #6 of 11 Old 04-24-2012, 04:43 PM
superj
its a hell of an idea. protects your stuff and your dog and is super cheap. it even matches fairly well. great job!!
you mock me with your garage.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 11 Old 04-24-2012, 06:48 PM
4x4JB
Nice cheap upgrade. Your shop has a ton of what my metal building shop will have. I have to ask though. WHAT'S THE DEAL WITH YOUR ATTIC ENTRANCE!! Lol ;-)
4x4JB is offline
post #8 of 11 Old 04-24-2012, 07:52 PM
mrmark
YOU SUCK I want a garage I can put a lift in !!!! I sometimes think about putting one next to the house and then building a cover over it, but you still suck
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #9 of 11 Old 04-24-2012, 10:09 PM
animal0307
12 foot ceiling and a broken string???
animal0307 is offline
post #10 of 11 Old 04-25-2012, 09:06 AM Thread Starter
pasinbuy
It is actually pretty cool. My attic is big enough to add rooms. Above my garage I installed the ladder to access a storage room that is tall enough to walk around.
My insulation is sprayed foam on the attic ceiling so even during the summer when most Florida attics get to be 130 degrees plus, my attic stay about 2 degrees warmer than the inside of my house. There is no need to close the attic up completely. So I leave the ladder out a bit for easy access.
Not sure what you mean by a broken string? Fill me in and I will try to address it.
Thank you, Even without the dog the mesh keeps honest hands out of my Jeep.
Nothing will keep a thief out
Thank you for the compliment.
pasinbuy is offline
post #11 of 11 Old 04-25-2012, 09:18 AM Thread Starter
pasinbuy
I have it made. If it is too hot to work I can close the garage door and blow cool air from the house into the garage. The garage is fully insulated.
As far as cost it was not much. If you have a place outside of you home. Just pour a six inch deep slab. I picked up my lift used for $450.00. Drop it on the slab and you are done. There is no need to cover up the lift outside that I can see. It is fine outside in my opinion.
A new cheap lift is about $1500.00 a good lift like mine is about $3000.00 new I would guess. I have plans to install two drive on lifts at the front of my garage for added storage. Which you can see I need.
pasinbuy is offline
Few easy upgrades for my Yj pasinbuy YJ Wrangler Technical Forum 22 06-01-2012 10:17 AM
A few easy upgrades, part two pasinbuy YJ Wrangler Technical Forum 0 04-23-2012 07:16 PM
Essential (cheap & easy) cosmetic & technical upgrades? ggking7 TJ Wrangler Technical Forum 6 10-21-2010 05:28 PM
Strenghten Dana 35/ Easy Upgrades? ohhpe YJ Wrangler Technical Forum 10 02-21-2006 02:08 PM
The easy part is over...now what do I do!? rhelton04 TJ Wrangler Technical Forum 6 02-20-2004 09:55 AM
