Few easy upgrades for my Yj - JeepForum.com
post #1 of 23 Old 04-16-2012, 10:48 AM Thread Starter
pasinbuy
I figured I would share some upgrades that I made to my rig over the years.
Some of the upgrades that I will show I have not seen that anyone else has done like the piece of 2" x 42" piece of aluminum that I notched out in the front and made a few minor and easy bends. If you look at the first pic it shows what the front view of my rig.
We all have the problem with water pooling on our tops after a heavy rain. Or flapping tops at certain speeds. Some have fixed this by construction PVC from the roll bar piece that goes to the window frame. Then the PVC goes from side to side above your head.
This idea works great cost practically nothing and can be made from scrap aluminum. Just notch out the front of the 2 inch aluminum, bend as the pictures show and place a piece of thick cloth on the front. Done deal and only took a few minutes to make. Fully removable in seconds.
EDIT: Before I add any more pics. Can someone tell me how to format the picture to fit? And to upload the right size.
pasinbuy is offline
post #2 of 23 Old 04-16-2012, 12:18 PM
Que89YJ
Really nice. Usually the pics resize automatically. For somew reason they didnt with this post. Good looking Jeep!
Que89YJ is offline
post #3 of 23 Old 04-16-2012, 12:45 PM
hdfxrs91
1987 YJ Wrangler
My Jeep came with a fancy pre-cut length of 1x4 to stand up from the floor of the Jeep to the roof. I think I like your idea better, although I rarely use the top anymore.
hdfxrs91 is offline
post #4 of 23 Old 04-21-2012, 09:31 AM Thread Starter
pasinbuy
Can someone tell me how to resize the above pictures. And how to insert the right size pictures?
pasinbuy is offline
post #5 of 23 Old 04-21-2012, 09:48 AM
GilNewJeeper
2008 KK Liberty
You need to use an external program ex. Microsoft Office Picture Editor, go to "TOOLS" and click on re-size or if you upload your pictures into "PHOTOBUCKET" click on the picture, check the menu and choose re-size.
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #6 of 23 Old 04-21-2012, 10:31 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I use photobucket and it seems to resize it perfectly. Btw nice innovation with running the top prop tri the windshield instead of across side to side. I think this is a better design for keeping water from pooling up when it rains.
Luck Favours The Prepared
Anticanman is offline
post #7 of 23 Old 04-21-2012, 11:19 AM Thread Starter
pasinbuy
Thank you. The piece works perfectly and only take a few minutes to make.
Plus it gives a lot more head room than with a pvc pipe above you.
I have uploaded to ImageShack. When I try to copy and paste the URL it states invalid. I cannot figure out what I am doing wrong.
pasinbuy is offline
post #8 of 23 Old 04-21-2012, 11:31 AM
MJDriver
MJDriver's Avatar
Well done. I hacked off the end of a mop handle so it sits in the cup holder and the mop head keeps the top up in the rain. Yours is a much better solution.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #9 of 23 Old 04-21-2012, 12:00 PM Thread Starter
pasinbuy
This is how I made my hand throttle. Cost was around $7.00. Very easy and only took about 15 minutes from start to finish. The longest part was drilling a hole in the firewall. Please note that this is for FI models only. Carb models you will have to make some changes.
I went to a bicycle shop and bought a Schimino shifter. It came with the cable and cost $5.00
Ace hardware had the 1/4 20 adjuster bolt and a sink clip. (A sink clips holds your stainless sink to the counter. So you know what you are looking for and can tell the sales guy.)
Pull the clicker out of the Schimino shifter and throw away the bolt install the adjuster bolt that you bought to hold your throttle at any RPM with a turn of the adjuster bolt.. I also used a piece of rubber hose to hold the new throttle control to the shifter. One finger throttle.
The third picture shows the sink clip bent over the FI throttle cable bracket.
On FI models there is a bracket with square holes this is where the sink clip holds the cable. (second picture) To hold the sink clip in place just bend it over the bracket. Run the cable and that is pretty much it.
Jeep shifter inside.jpg   Jeep shifter front of clip to end of cable.jpg   Jeep back of sink clip1.jpg
pasinbuy is offline
post #10 of 23 Old 04-21-2012, 12:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You need IMG codes with the URL of the pic
post #11 of 23 Old 04-21-2012, 04:55 PM Thread Starter
pasinbuy
For the life of me I cannot figure it out. When I go to imageshack and copy the URL the Forum states that it is invalid. http://imageshack.us/g/842/jeepbackofsinkclip1.jpg/
pasinbuy is offline
post #12 of 23 Old 04-24-2012, 11:21 AM
EABiker
Nice fab work! (I think I can see the molecules of your Jeep in those pics! )
EABiker is offline
post #13 of 23 Old 04-24-2012, 11:29 AM
kjg26
kjg26's Avatar
You have model number or part number for the shifter?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #14 of 23 Old 04-24-2012, 11:45 AM Thread Starter
pasinbuy
From what I understand just go to any bicycle shop and ask for a Schimino shifter. It will come with cable and when you move the lever it will click. Take the clicker piece out.
The Schmino shifter is used to change gears on bicycles.
pasinbuy is offline
post #15 of 23 Old 04-24-2012, 11:51 AM
kjg26
kjg26's Avatar
Gotcha. Thanks.
kjg26 is offline
Essential (cheap & easy) cosmetic & technical upgrades? ggking7 TJ Wrangler Technical Forum 6 10-21-2010 05:28 PM
So many soft tops to choose form, just want one thats easy on easy off. mgdenver TJ Wrangler Technical Forum 9 04-29-2010 01:18 PM
Strenghten Dana 35/ Easy Upgrades? ohhpe YJ Wrangler Technical Forum 10 02-21-2006 02:08 PM
Wheel Stud replacement: easy or not so easy? MR.CLIFFORD TJ Wrangler Technical Forum 12 08-24-2003 12:17 AM
