Fender Flares Picture Request - JeepForum.com
post #1 of 29 Old 08-07-2011, 02:08 PM Thread Starter
Max4Speed
I am looking to replace the factory flares with aftermarket ones and there is so much available. I am shopping for wheelsand tires as well so wanted to see what different setups are folks using out there. 95 YJ with a 3" body lift right now. Since it is a 4 banger I am thinking about sticking to 33s unless someone can tell me otherwise.
Pictures of ANY aftermarket fender flares you got would be helpful!
Max4Speed is offline
post #2 of 29 Old 08-07-2011, 02:37 PM
jeepyj13
Not 7 inch rugged ridge flares but 6 inch tag pocket flares i just installed on my yj.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 29 Old 08-07-2011, 02:44 PM
attentionwhore
What wheels/tires are you running? Depending on the size, there are different recommendations that can be made. I had the same question a month ago and decided against the 7" rugged ridge flares. I have 33x12.50's and the 7" flare would have stuck out a bit too far leaving the flare vulnerable to trees and whatnot instead of the tire. I chose to go with 6" Xenon's instead. I saw a set on ebay yesterday at a really good price. Here is the link http://cgi.ebay.com/ebaymotors/Xenon...mZ250868470928
attentionwhore is offline
post #4 of 29 Old 08-07-2011, 02:52 PM
Lre78hd
I have a set of 7 inch rugged ridge with a set of 33/12.50 s but I cant load pics I can email them to you
Lre78hd is offline
post #5 of 29 Old 08-07-2011, 03:07 PM
Burlbook48
Burlbook48's Avatar
Most recent pics I have are in this thread, they'll show the 7" Rugged Ridge flares from different angles. SOA on 33x12.50-15 rubber, 8" wheels, D44's front and rear with 1" spacers wheel spacers on the rear.
http://www.jeepforum.com/forum/f7/i-...heavy-1248720/
Before and after pics of the 7" flares for comparing against the stock flares;
http://www.jeepforum.com/forum/f12/r...l-pics-564152/
Hope that helps.
Burlbook48 is offline
post #6 of 29 Old 08-07-2011, 03:37 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Here's a pic of my old YJ it had the 7" rugged ridge flares, the tires are 33x12.50's on 15x10" wheels with 4" backspacing
I never had any problems of mine getting stuck on trees or rocks ,
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 29 Old 08-07-2011, 03:52 PM Thread Starter
Max4Speed
Thanks for the ideas folks! At this point I have not purchased anything so point of this post was to get some ideas. I have 31x11.50.15s right now with a 3inch body lift. Shopping for new wheels/tires combo as well.
Keep the pics coming
post #8 of 29 Old 08-07-2011, 06:31 PM
jonzjeepyj
Go For It. Re geared the little 2.5 does well. I'm running 35
BFG TA-KO's. With the 2.5L motor, every upgrade counts. It
runs great. Will it ever be a 4.0L Jeep, NO. But it runs very
well and does everything I want it to.
4.0L TB upgrade
Bored out intake to match
19lb injector upgrade
Super Coil and Live Wires
14" electric fan conversion
High flow muffler
Re gear to 4.88's front and back
92YJ / 2.5L / 5-Speed / D30-35 / 4.88's / AX5 / N231J
TeraFlex High Steer Kit / Solid Front Axle Conversion
Super Coil / Live wires / 14" E-Fan / 4L TB / 19lb Injectors
AA-SYE / CV Rear DS / 1" Lift S-Reversal Kit Up Front
1" lift Shackles Rear / 4" RC Lift SUA / 1" Daystar Body Lift
Hack and Cut Flatty Front Fenders / TJ Rear Fender Flairs
35x12.5x15 BFG TA KO's / 15x10 AR Outlaw 1 Wheels
High Lift Jack / D-Rings / 9000lb Winch / Tow Hooks
There is no problem that can't be fixed if you throw enough money at it.
jonzjeepyj is offline
post #9 of 29 Old 08-07-2011, 07:08 PM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by jonzjeepyj View Post
Go For It. Re geared the little 2.5 does well. With the 2.5L motor, every upgrade counts. It
4.0L TB upgrade
High flow muffler
X2 you hit the nail right on the head ! if you look at my sig both of my wranglers were 2.5L's.
I ran 33's on them both with 4.88's, The also were treated to a Header, catback exhaust, 4.0 Tb/Tb spacer, ported intake to match opening, 19# injectors, cai, Eletric Fan conversion they ran great on the hiway and offroad.
My TJ had to get a reman engine after it threw a rod so the replacement was Bored .040 , shaved the head, mopar purple cam, and yellow terra roller rockers. with the all the other performance parts it was a pretty peppy for a 4banger
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 29 Old 08-07-2011, 11:49 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Xenons, rear only.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #11 of 29 Old 08-08-2011, 10:57 AM
klrstew
ebays, TAG 6" flares. I'm happy with them. I personally don't like the look of the 7" because I like my tires to hang out a little.
33x1250x15s
klrstew is offline
post #12 of 29 Old 08-22-2011, 06:51 PM
zte87
GIVE IT THE ONION
zte87's Avatar
are those 10 wide or 8 wide wheels?
zte87 is offline
post #13 of 29 Old 08-22-2011, 07:22 PM
Noltz
YJ Wrangler
OEM Rubicon flares on my YJ. 15x10 Wagon rims, 4" offset, 35x12.5 KM2's. They stick out about 2". I'll try for a straight on shot tomorrow (dark now).
Edit; Found older pic!
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #14 of 29 Old 08-22-2011, 10:52 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Smittybilt src rear tj flares with custom vise grip mounting mod!
Luck Favours The Prepared
Anticanman is offline
post #15 of 29 Old 08-23-2011, 07:34 AM
Que89YJ
Try this post. I have these wautung to be put on:
http://www.jeepforum.com/forum/f12/d...l#post12060414
Que89YJ is offline
Selling my Bushwacker fender flares replacing with Rubicon flares domano 68 TJ Wrangler Technical Forum 30 02-14-2011 08:29 AM
Removing pocket-style fender flares replacing with factory flares domano 68 TJ Wrangler Technical Forum 18 04-09-2010 06:17 PM
LJ Picture request: wheel well and underneath fender flares domano 68 TJ Wrangler Technical Forum 4 03-04-2010 06:33 PM
Fender Flare Extensions for keeping grim off rear fender flares? FrankGG TJ Wrangler Technical Forum 7 12-05-2007 09:29 AM
YJ homecut flat fender *PICTURE REQUEST* Roach YJ Wrangler Technical Forum 9 08-10-2006 03:32 PM
