Fender Cutting - JeepForum.com
post #1 of 7 Old 12-03-2007, 08:31 PM Thread Starter
jschroder
Fender Cutting
I installed a 4" RC lift and put on 33x12 tires and after going out a couple times I have broken my fender flare and noticed I am rubbing the body quite a bit with the tires. Any suggestions on getting a little more clearance? Should I cut the fenders out and install newer style flares? Has anybody had this same problem and dealt with it by cutting?
88 YJ with a few junkyard parts.
jschroder is offline
post #2 of 7 Old 12-03-2007, 08:41 PM
dadstoy
TJ Flares, trim fender, 1 or 2" body lift, and adjust your bump stops. I have the flares, trimmed fenders and 3" BL and rub to the point that I cracked both front fenders. I have not adjusted my bump stops though.
dadstoy is offline
post #3 of 7 Old 12-03-2007, 09:25 PM
will_982
I got the Rough Country fender flares, because they were cheapest. They are TJ style rear flares and require you to cut the back of the of the fender. Wasn't to bad to do.
will_982 is offline
post #4 of 7 Old 12-04-2007, 08:16 AM
doug_1994
doug_1994's Avatar
Dadstoy is correct.
Do you have bumpstops set correctly?
I have major fender trimming on my pile, but I run 40's on stock springs SOA. I have no rubbing what-so-ever.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #5 of 7 Old 12-04-2007, 08:17 AM
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
I'm not sure that I would ever install even a 2" BL, much less a 3" BL
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline
post #6 of 7 Old 12-04-2007, 09:11 PM Thread Starter
jschroder
Thanks guys. That's kind of what I thought I just wanted to make sure. Now I've got another project to keep me busy on the weekend.
post #7 of 7 Old 12-05-2007, 06:17 AM
dell2028
dell2028's Avatar
I have a set of TJ flares. If you want them PM me. Keep cutting till there is no rubbing.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
33s, small lift, fender cutting - looking for input. Brandon_YJ YJ Wrangler Technical Forum 9 12-15-2008 07:57 PM
Fender Cutting CarsonKetrowYJ YJ Wrangler Technical Forum 9 03-13-2006 08:02 PM
dread cutting a huge cavern in inner fender! urbanassault TJ Wrangler Technical Forum 12 01-24-2005 11:34 AM
fender cutting YoungJeeper YJ Wrangler Technical Forum 2 12-23-2003 06:04 PM
cutting fender flares cmoore TJ Wrangler Technical Forum 5 07-21-2003 11:49 AM
