Fender Cutting - JeepForum.com
post #1 of 10 Old 03-10-2006, 08:29 PM Thread Starter
CarsonKetrowYJ
Fender Cutting
Well I have already cut the front fender out of my 87 YJ but I was wondering, when I cut the rear fenders out, where should I re-route the gas cap? I figured I could fab-up some new tail lights, but I need a place to put the gas cap. Any ideas?
CarsonKetrowYJ is offline
post #2 of 10 Old 03-10-2006, 08:37 PM
Roach
Roach's Avatar
If you dont use the rear section, You should get a fuel cell
Cucarachón
Roach is offline
post #3 of 10 Old 03-10-2006, 08:45 PM Thread Starter
CarsonKetrowYJ
and if I do use the rear section?
post #4 of 10 Old 03-11-2006, 06:08 AM
ncjeepinyj
ncjeepinyj's Avatar
Are you doing like a comp cut? If not you shouldnt have to move it.
95 YJ, SOA, 35's, 4.88's, 8.8
ncjeepinyj is offline
post #5 of 10 Old 03-11-2006, 09:20 AM
biggreentj
i just put PSC comp corners on mine, and i moved the gas tank inside the jeep.
if u dont do comp cut you will be fine, or if u do model it after the BTF ones and it would prolly work. but if you do anything other than trimming the rear you will have to cut into the braces that hold the tailgate hinges and the rear roll cage, even though they wouldnt hold up in a roll, it will still take alot of strengh away from the rear panels and inner panels
91 YJ 4.0/ax15 Stretch to 102" D44s 5.38s Detroits/Hi Steer/38.5"TSLs/Custom full cage/ Corbeau seats/Crow Harnesses/PSC comp corners.
biggreentj is offline
post #6 of 10 Old 03-12-2006, 07:04 PM Thread Starter
CarsonKetrowYJ
What exactly is a comp cut out? and what kind of replacements for the tailgail are there, if I were to do a comp cut out?
post #7 of 10 Old 03-12-2006, 09:07 PM
biggreentj
this is comp cut, i used Poison Spider Customs, but some people just cut the back, which is what i did, but then added these pieces. the tailgate stays the same.
main reason for this is to extend wheel base, which i plan on doing next. but it also gives tons of clearance.
let me know if u have other questions
post #8 of 10 Old 03-13-2006, 11:52 AM
ghiradelli777
PSC is the way to go!!!
i would give them a try if you are looking for a good corner setup....
if the jeep is not going to stay on the road, you could put the gas cap in side the truck of the back
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #9 of 10 Old 03-13-2006, 04:52 PM
MRVIC91YJ
i can't recall where is seen a picture of a jeep with a comp cut very much the same as the red jeep in the pics above. the guy had kept the gas tank in stock location and the gas cap was right below the drivers round LED lights in the same location as the jeep above. it might have been in the new JP magazine and it was a white TJ i think
91 YJ SOA, AMC 5.9L 360, tf727, d300, d44 and ford 8.8, 35 TSL SX
93 Cherokee Country, 4.0L auto, 4" lift, 30" BFG
MRVIC91YJ is offline
post #10 of 10 Old 03-13-2006, 08:02 PM
biggreentj
you can keep the jeep daily driver and move the tank inside the jeep, thats how mine is. also BTF makes some comp cuts that might have room to keep stock filling location, not sure, but these PSC ones are great, these are actually made for a tj, so if anyone gets some make sure u get yj ones( i got a great deal on these slightly used is why)
but i have seen people just cut the body for this look and "looks" just as good, wont be anywhere near as strong, but for looks and clearance it will work
33s, small lift, fender cutting - looking for input. Brandon_YJ YJ Wrangler Technical Forum 9 12-15-2008 07:57 PM
Fender Cutting jschroder YJ Wrangler Technical Forum 6 12-05-2007 06:17 AM
dread cutting a huge cavern in inner fender! urbanassault TJ Wrangler Technical Forum 12 01-24-2005 11:34 AM
fender cutting YoungJeeper YJ Wrangler Technical Forum 2 12-23-2003 06:04 PM
cutting fender flares cmoore TJ Wrangler Technical Forum 5 07-21-2003 11:49 AM
