Felpro or Victor Reinz or ? - JeepForum.com
post #1 of 2 Old 11-28-2011, 10:59 PM Thread Starter
Delta347
So I am doing a 5.2L swap and want to redo all the seals and gaskets before I put it in.
I used felpro on the 4.0L I was going to swap in before changing my mind to the V8 I had sitting around.
So what brand do you all use/recommend?
Felpro, Victor Reinz, or some other readily available option?
...PS If you know a good, low price place to get ECMs flashed I need to redo the 5.2L's ECM for manual and no alarm.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #2 of 2 Old 11-29-2011, 08:17 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I've always used Fel Pro gaskets.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
Felpro permadry oil pan gasket Chris Aunchman YJ Wrangler Technical Forum 1 05-18-2011 08:21 AM
Felpro or Hesco Oil Pan Gasket MEnginerd TJ Wrangler Technical Forum 3 04-05-2008 06:25 PM
Anyone Use Felpro Seals? RLD831 TJ Wrangler Technical Forum 6 03-29-2008 12:12 PM
anybody with american racing victor wheels willtjx TJ Wrangler Technical Forum 9 11-21-2004 09:14 PM
American Racing Victor Teflon Wheel elmo510 TJ Wrangler Technical Forum 5 09-12-2004 06:17 PM
