Feetwet's Hand Throttle Install - Page 2 - JeepForum.com
post #16 of 29 Old 06-14-2012, 01:27 PM
jeepster93
jeepster93's Avatar
I got the cheapest shifter I could find.
I think the whole thing cost me $17.00
I use it for the winch and belt driven oba.
The connection to the throttle body.
The hold down/adjuster. I went high tech...
jeepster93 is offline
post #17 of 29 Old 06-14-2012, 01:38 PM
jeepster93
jeepster93's Avatar
Have you driven around with it yet?
I don't mean using it as a "poor mans cruise control", but just normal driving?
When I 1st hooked mine up to the throttle body, it would/could interfere with the gas pedal. The engine would sometimes, NOT return to idle, but race a bit.
It did that randomly/ intermittently until I went to home depot and got that little gray thing that hooks to the throttle(in the 2nd pic above). I also had to epoxy the end of the black housing for the cable into the adjusting ferule it goes into in my pic 3 above. Otherwise the slack in the cable when I press the gas pedal would bugger things up a bit, and the engine would race a bit.
Just a heads up...
post #18 of 29 Old 06-14-2012, 01:54 PM
pasinbuy
I used a sink clip from Ace Hardware or any home supply store to hold my cable. The sink clip fit perfectly in the square hole above in Jeepster's picture. Just push the sink clip in the square hole and bend the excess over the top. Fast and easy.
The sink clip took 15 seconds to install and looks like a factory install. ( My opinion.)
pasinbuy is offline
post #19 of 29 Old 06-14-2012, 02:08 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Originally Posted by Feetwet View Post
Hey Fernando! What would you like to see? First pic has the lever, second to last has the lever installed. Anything special you want to see?
Nevermind man, thanks! for some reason this morning I skipped the last pic!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #20 of 29 Old 06-14-2012, 02:20 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Great write up
Luck Favours The Prepared
Anticanman is offline
post #21 of 29 Old 06-14-2012, 04:06 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
You mean Lunch?
That's not like you, you read everything!
Thanks for the kind words, Aman...
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #22 of 29 Old 06-14-2012, 04:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Definitely going to bump this up to the next project I start after I finally finish one.
post #23 of 29 Old 06-14-2012, 05:51 PM
pasinbuy
The whole project takes about 15 minutes.
pasinbuy is offline
post #24 of 29 Old 06-14-2012, 08:40 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Most of my projects take about that long. My butt just doesn't have a forward moving gear as of late.
post #25 of 29 Old 06-14-2012, 08:48 PM
gunshw301
Thanks for the write up.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #26 of 29 Old 06-14-2012, 08:53 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I love my hand throttle. I'd never wheel a manual rig without it.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #27 of 29 Old 06-15-2012, 03:49 PM
mazyj
Just a heads up...
Jeepster93 has a good point here. I installed a setup almost exactly the same as yours and it worked great for a while but every once in a while not allow the jeep to return to idle. Its not the end of the world as normally just revving with the hand throttle would free it up. Only once did I actually have to get out and take the cable off the throttle body because it would not drop lower than 2500 rpm's.
A suggestion for anyone considering this project- instead of WD40 or grease use mountain bike cable lube from a bike shop. WD40 and grease will make it slippery to start with but get gunked up quickly inside the cable housing and could cause more problems in the end.
All in all a great write up though!
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #28 of 29 Old 06-15-2012, 04:38 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Cut and pasted from post #4...
"Some concerns I had never arose. I've seen some setups using a chain to connect to the throttle linkage so as not to hinder normal throttle operations. I wasn't sure if my new cable would interfere with smooth pedal operation, but it doesn't. The new cable goes slack when the gas pedal is pressed. No worries."
The WD-40 was a VERY LIGHT coating, used ONLY to aid in threading the wire down the sheath. Both ends are virtually sealed by the end cap ferrules. The wire is galvanized. I don't anticipate any more crud getting in there than has gotten into the original throttle cable in 17 years....
Feetwet is offline
post #29 of 29 Old 06-16-2012, 09:08 AM
pasinbuy
Put some slack on you cable to allow the idle to be from the pedal only.
Grease is much better than cable lube. Due to the thickness it will last longer. It will not gunk up and actually help water proof the cable. Cable lube is very thin.
pasinbuy is offline
Hand Throttle Install Details srlbotanical TJ Wrangler Technical Forum 4 07-11-2012 09:10 AM
Throttle lock/ hand throttle / electronic throttle???? PlaneJob TJ Wrangler Technical Forum 4 03-04-2012 07:45 PM
My hand throttle install YJames90 YJ Wrangler Technical Forum 6 01-25-2008 07:00 PM
Hand Throttle Install FlyersFan2009 TJ Wrangler Technical Forum 10 04-12-2005 04:38 PM
My hand throttle install (Pics) Sia YJ Wrangler Technical Forum 2 07-31-2003 06:42 PM
