fault codes - JeepForum.com
post #1 of 7 Old 06-18-2009, 06:02 PM Thread Starter
BadApple1403
fault codes
im getting fault codes 12 ,33,52,15. it wont run..would any of these be possible causing it to not start..was was running fine the just died out like it was running out of fuel..i have fuel pressure at the rail...ne suggestions??
BadApple1403 is offline
post #2 of 7 Old 06-18-2009, 06:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here are the fault codes, starting with post #6 from the FAQ's.
http://www.jeepforum.com/forum/f12/frequently-asked-questions-faq-your-answers-usually-here-451154/
Fault Codes
12 Battery disconnect
15 No vehicle speed (distance) sensor signal
33 Air conditioning clutch relay circuit
52 O2S signal stays above center (rich)
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 06-18-2009, 06:10 PM Thread Starter
BadApple1403
thx but i've read thru the codes not really sure if any of these would cause it to not start
post #4 of 7 Old 06-18-2009, 06:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I wasn't sure if you had them, so I posted them. I really can't see any of them causing a "no-start" situation either.
Max
Mean Max is offline
post #5 of 7 Old 06-18-2009, 06:47 PM
Louie4
Do you have spark a spark to the distributor?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 7 Old 06-18-2009, 09:12 PM
havasu
On permanent vacation
havasu's Avatar
Did you end up with a # 55? If not, do a recount to confirm.
havasu is offline
post #7 of 7 Old 06-20-2009, 12:21 PM Thread Starter
BadApple1403
thanx max i didn't think anything should cause it to not start either..time to start trouble shooting ..and yes there was a 55
Fault Codes? SEMO 95 YJ YJ Wrangler Technical Forum 0 02-14-2008 04:41 PM
95 yj 2.5l fault codes? noturaveragehak YJ Wrangler Technical Forum 3 09-06-2007 09:29 PM
fault codes tuckinauster TJ Wrangler Technical Forum 3 09-11-2006 09:56 AM
fault codes ember YJ Wrangler Technical Forum 7 03-21-2006 02:39 PM
Fault codes? CosmicCreeper YJ Wrangler Technical Forum 10 01-22-2005 09:37 AM
