Quantcast A Father and Son 87 YJ Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > A Father and Son 87 YJ Build
Old 11-03-2008, 02:05 PM   #1
UnderPar
1987 YJ Wrangler
I started my original thread over in the Jeep Registry but it seems to fit better here. Here's the summary and I'll catch you up to date.
It has always been my dad's dream that one day we would do a frame off together. I went to college, got married, and moved away. Last year he was diagnosed with cancer. Two months later he bought this YJ. 1987 4.2L Auto 89,000 miles.
We didn't do any research. Hell, I didn't know that he was planning on buying anything, so he didn't know what to look for. Naturally it has all the typical issues and more. Seatbelt mounts/rockers, floorboards, windshield frame and hinge area, tailgate, frame rot rear shackle mounts and had been in an accident.
After some disassembling.
Rusted floor pan.
Rusted rocker - my arm fits through this hole.
UnderPar is offline   Reply With Quote
Old 11-03-2008, 02:18 PM   #2
UnderPar
1987 YJ Wrangler
The basic build plan is to fix all the rust damage and install a 4in lift to clear 33s. Everything else is still up for debate.
The tub off the frame.
21 years of rust.
What a mess. You have to love 1980's technology.
The axles are out.
I'm open to any ideas or suggestions you guys might have that will help my dad and myself with this build.
Old 11-03-2008, 02:40 PM   #3
firefighter315
Omnis Cedo Domus...
firefighter315's Avatar
Sounds like a great, and long, project. Tons of frame off rebuild info here on JF of course. My guess is to make sure you have at least one or two hundred grinding wheels on hand! The good thing is that with so much work to be done, it will give you TONS of time to spend with your Dad in the garage.
p.s. You are in a great area for wheelin'....I went to college (M.C.) there for a year and really liked the area a lot......
firefighter315 is offline   Reply With Quote
Old 11-03-2008, 02:44 PM   #4
Jeepsr4me19
1976 CJ5
Start with the frame. Look it over good to see what kind of rust your going to have to repair. Then go ahead and mount you new axles while the body is off. Much easier. Go find a 91and up Cherokee(they are everywhere cheap) and get the motor and trans out of it to replace the one you got. EFI is nice. Make sure all your body mounts are solid on the frame and body. The rest is just patch panels. treat the rust with a good rust stop. There is a ton of stuff to do a body off right. You will have roughly the same in this as going and buying a newer model needing nothing other than driving. I understand you want to spend time with your father and this is a good way. I would rather be going and wheeling or riding instead of busted knuckles and sore muscles from all the work needed.......
I only read the pictures.
Jeepsr4me19 is offline   Reply With Quote
Old 11-03-2008, 02:50 PM   #5
blue1989yj
As said, start with the frame. Since you are going to do it all, do it right. Replace any old fuel lines, brake lines, brakes, gaskets, etc. No need to have to take it apart again once you are finished. Are you keeping the 4.2L engine? If so look into the Nutter Bypass and eliminate most of the vacuum lines under the hood. Most of all, don't let this be a "rush" project. Take the time to spend with your father and enjoy it. There are tons of threads here on rust treatment and fixing. Keep us updated as we all like pics.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline   Reply With Quote
Old 11-03-2008, 04:33 PM   #6
UnderPar
1987 YJ Wrangler
Both of the rear shock mounts were rusted through and the rear cross member looked like swiss cheese. I know that I could have fabbed up some of my own but we are lacking in the scrap metal department at the moment. I called a local shop and they only sell full sheets 4x8 and that would not help with the shock mounts. I was also a little worried about how precise the body mount holes would have to be so I ended up buying all three pieces from the jeep dealer for $78.
1987 - YJ 4.2 Auto - Build Thread
1986 - Corvette
2001 - Explorer
2009 - A4
Old 11-03-2008, 04:34 PM   #7
krd
wow, i went through the same problems with my build up.
258 str.6 w/1" mml, nuttered, 32/36 weber carb, hei, TF-999 w/hurst floor shift, np231 w/aa slip yoke eliminator, jks quick discos, 3-1/2" fabtech, 1" bl, MORE 5/8" boomerangs front and rear, dana 44's front and rear 4.56 locked, herculined tub and family style roll bar, jks u-bolt plates, xenon flat fenders, rrc pre-runner, custom built rear bumper, Gen-right rock sliders and hood louvers, 35" mtz micky t's, bullet proof high steer, bestop soft top w/tinted windows.
1988 yj
2007 gmc 2500 crew cab
2009 volvo xc70 turbo
1988 porsche 911
krd is offline   Reply With Quote
Old 11-03-2008, 06:03 PM   #8
KTM265
That turned out really nice...
Mark Twain: [u]"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore, dream and discover"..[url=http://www.Kawiecentral.com].[/url][url=http://www.kawiecentral.com].[/url][/u]
KTM265 is offline   Reply With Quote
Old 11-03-2008, 06:16 PM   #9
Brandon_YJ
1987 YJ Wrangler
Wow, this would make for some sort of human interest story in a Jeep magazine.
(and I don't mean that sarcastically)
Looks like you have your work cut out for you though, but being a YJ it is very easy to work on, weld on, hammer, on, fab on, etc.
Good luck, and expect a PM from me shortly.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Old 11-03-2008, 06:39 PM   #10
Mean Max
Mean Max's Avatar
What a great story & project!
I did a complete teardown/rebuild project with my Dad many years ago on an MG Midget, it was a good time.
Sorry to hear about your Father's poor health. My Dad is in bad shape these days, and I live 12 hours away from him. That sucks.
I'm down here in south Florida, and my Dad is basically your "neighbor" over in Newland N.Carolina, just a couple of miles away from you.
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 11-03-2008, 06:45 PM   #11
93jeepyj
wow sorry to hear about your pops, thats a great way to spend time with him though. what are your plans for the drivetrain?
93jeepyj is offline   Reply With Quote
Old 11-03-2008, 07:07 PM   #12
UnderPar
1987 YJ Wrangler
For now the plans are to use the stock drivetrain. Dad drove it 130 miles home when he bought it, so it is in fair shape. The problem was that it only got 11mpg on that trip. I will be removing the MCU and intalling an MC or Weber carb and doing the nutter bypass. I plan on having it on the road by spring. Down the road though it will be getting new axles and prob a 5.3L.
Old 11-03-2008, 08:12 PM   #13
93jeepyj
sweet! sounds like its gonna be a fun project and a sweet jeep when you guys are done... then again it is a jeep so its never really done
Old 11-03-2008, 08:59 PM   #14
JFranko
JFranko's Avatar
You'll have plenty of time with your dad in the garage. My dad an I did a rebuild that took nearly 4 years to complete ( started when I was in 8th grade, didn't have to have it until I was 16 so there was no hurry). It's sad that you and your dad are going to have to do it with such a burden, but you'll still have a great time doing it.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline   Reply With Quote
Old 11-06-2008, 06:09 AM   #15
greenmanalishi
way to go man !!!
being a father of two wonderful young boys i look toward the day they can drive but spend as much time with the old man,
enjoy,enjoy enjoy
cheers
jim
greenmanalishi is offline   Reply With Quote
Glock Forum
