fan wiring question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > fan wiring question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 03-18-2010, 06:11 PM   #1
jodylikeamelody
fan wiring question
I am installing an electric fan on my wife's 4.0 and I have a question. I have the summit universal fan wiring kit and i wanted to know where people plumbed the thermoswitch in at. It states in the direction to put in the head or intake wherever you application allows and I am not seeing any open stops to plumb the switch in. Anyone ran into this before?
jodylikeamelody is offline   Reply With Quote Quick reply to this message
Unread 03-18-2010, 07:04 PM   #2
Djsthe1
Most people push them through the radiator fins.
Djsthe1 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2010, 07:07 PM   #3
Mark05059
some of those had a port in the t-stat housing. You could also get a T and remove the temp sender for the light and install it there.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 03-19-2010, 01:07 PM   #4
jodylikeamelody
will you get a good reading if you T it off? I guessing it would be fine, anyone have any troubles with T-ing it there?
Unread 03-19-2010, 09:29 PM   #5
K4KAS
Ive never had a problem using T's i nthe past on other vehicles. Even if it did, you could just adjust the fan temp setting to compensate to make the fan kick on earlier or later.
K4KAS is offline   Reply With Quote Quick reply to this message
