Fan shroud after AX15 - JeepForum.com
post #1 of 8 Old 02-16-2013, 07:42 PM Thread Starter
epettit
I just finished the AX15,NP231,8.8 install and when I started the enginei i noticed the fan not moving with the engine running. I shut it off and saw the fan rubbing on the lower part of the shroud. When I did the swap out I tucked the belly back up (it had 2"spacers) but I thought it was not big deal because it was going back to stock configuration.
I removed the shroud and noted the fan clutch was parallel to the radiator and about a 1/2 Ito 3/4 inch from the radiator but the fan looked low on the radiator. The mounting looks to be stock but I don't know being family new to jeeps
Any ideas????
Ed Pettit
epettit is offline
post #2 of 8 Old 02-16-2013, 07:58 PM
coolin4u
Did the jeep have a body lift on it when you purchased,if so the shroud may have been relocated when it was installed
coolin4u is offline
post #3 of 8 Old 02-16-2013, 08:04 PM Thread Starter
epettit
I don't think the previous owner lifted the body by looking at the mounts
Ed Pettit
epettit is offline
post #4 of 8 Old 02-16-2013, 08:45 PM
Mark05059
just relocate the fan shroud lower (or higher) on the radiator so it will clear the fan.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 02-17-2013, 06:38 AM Thread Starter
epettit
I probably will but it just bothers me that all is stock in the mount department and something is off somewhere causing the fan to rub the bottom of the shroud. I think I might look at the motor mounts a little closer although yesterday when I took a quick peak at them they seamed to look OK
Ed Pettit
epettit is offline
post #6 of 8 Old 02-17-2013, 06:51 AM
Louie4
If you snap a few pics of the mounts (engine & body) we can tell what you have. I had to relocate my shroud after my 1" body lift.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 8 Old 02-17-2013, 07:48 PM Thread Starter
epettit
Here is picture of the body mounts
Ed Pettit
epettit is offline
post #8 of 8 Old 02-17-2013, 08:28 PM
Louie4
Stock indeed. I would just try to relocate the shroud like said above.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
