fan clutch temp - JeepForum.com
post #1 of 6 Old 08-20-2011, 07:48 PM Thread Starter
sptrmike
sptrmike's Avatar
fan clutch temp
i wanted to replace my 195 thermostat with a 160, i have a stock thermal fan clutch, can anybody tell me if this would keep the engine bay temp to cool for the fan to work properly or would i have to go to a non thermal fan clutch.
thanks mike
sptrmike is offline
post #2 of 6 Old 08-20-2011, 08:03 PM
Louie4
"You pass butter"
Louie4's Avatar
First off, why are you going win a 160 thermostat? Secondly, the non-thermal fan clutch will keep things cooler since it has a constant amount of drag versus a thermal one which increases with temperature.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 6 Old 08-20-2011, 09:41 PM Thread Starter
sptrmike
sptrmike's Avatar
i just rebuilt my engine and i'm trying to make it last i spent a lot of hours and money getting this rig mechanicly sound
sptrmike is offline
post #4 of 6 Old 08-20-2011, 10:44 PM Thread Starter
sptrmike
sptrmike's Avatar
i talked to a tech guy at summit racing , he told me that running a 160 would possibly not let my engine get hot enough to evaporate moisture in the engine causing sludge and acids, also that the air fuel mixture could seperate washing oil off the cylinder walls. i'm leaving the 195 in.
sptrmike is offline
post #5 of 6 Old 08-21-2011, 07:51 AM
Mark05059
good choice. Running cooler doesnt always mean its running better... Leave the 195 in there. Our jeeps run at 210 and are fine.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 6 Old 08-21-2011, 08:05 AM
Louie4
"You pass butter"
Louie4's Avatar
Agreed. They do like the warmer operating temp. I believe it burns the fuel a lot better in the 180-210 range.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Engine temp high, Fan clutch questions TanTJ04 TJ Wrangler Technical Forum 10 06-24-2010 06:36 PM
Clutch Chatter when temp is 40-50 degrees garbon2535 TJ Wrangler Technical Forum 4 02-03-2010 07:54 PM
No clutch at running temp on 98 TJ hoytpotater TJ Wrangler Technical Forum 8 12-14-2009 03:40 PM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 10:01 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 10:41 AM
