Fan clutch - JeepForum.com
post #1 of 8 Old 12-19-2011, 09:48 PM Thread Starter
JUNKYARDDOG01
Fan clutch
Hello all,
I was checking out the engine compartment of my newly aquired jeep. I happen to spin the cooling fan and noticed it move pretty easily. Should the fan be pretty hard to turn manually??
JUNKYARDDOG01 is offline
post #2 of 8 Old 12-19-2011, 09:58 PM
1998zj
It spins easily when the engine is cool. If doesn't over heat you are fine.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 8 Old 12-20-2011, 05:37 AM
bogleparsons
It should spin easily when cold yes.
If it doesn't ( like mine) then your fan clutch is seized
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #4 of 8 Old 12-20-2011, 12:04 PM
1998zj
Mine froze up so I put on a Taurus fan.
1998zj is offline
post #5 of 8 Old 12-20-2011, 01:37 PM Thread Starter
JUNKYARDDOG01
thank you all..
post #6 of 8 Old 12-21-2011, 09:09 PM
Schaef81
If youre worried about the functionality of the fan clutch it can be tested. Removed the silver spring going through the clutch and rotate the fan clutch counterclockwise and install the spring. This makes the fan spin like a conventional fan not a temperature determinate fan. If overheating persists just replace it. Doesn't sound like you have an overheat problem tho.
Schaef81 is offline
post #7 of 8 Old 12-21-2011, 09:14 PM
Savanna
If it spins more then about 5-8 times after you turn off the engine, it might need replacing. Mine was pretty easy to spin, and low and behold, a night camping up in the mountains and riding for a few hours led my jeep to overheat (took hours to cool down in almost freezing weather)
But instead of dumping more then $70 on a mopar fan clutch, make sure u need one.
Savanna is offline
post #8 of 8 Old 12-22-2011, 09:27 AM
pasinbuy
If it spins freely with no drag, it is bad..
If it has and front to back motion with your hand, it is bad.
If it is locked up and does not spin, it is bad.
pasinbuy is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 05:49 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
