Fan belt???? - JeepForum.com
post #1 of 4 Old 05-10-2002, 03:17 PM Thread Starter
TDanks76
1979 CJ7
Fan belt????
How do you change these things. i couldn't find a tension spring like on the Ford motor. Whats the deal??? Can anyone help me out?
CJ 7, with the good stuff.
TDanks76 is offline
post #2 of 4 Old 05-10-2002, 03:19 PM
Loppy
Why do you have 2 of these posts up? Are they two different jeeps?
DisFUNctional.
Loppy is offline
post #3 of 4 Old 05-10-2002, 10:59 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
K, Hopefully its like the 92' but here it goes. Over on the right side (driver side) look down and you will see the pulley farthest to the right there, look around and you'll find a slide type thingy. There are 3 bolts to lossen. Do so and the pulley will slide along the track inward, change it and when your tightening them back on, there is a pully on the left that has no real purpose, and just spins. Take that off and tighten everything as much as u can. Then replace that pully to add the extra tension.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #4 of 4 Old 05-10-2002, 11:49 PM Thread Starter
TDanks76
1979 CJ7
Thanks I'll have to check that out. And this post in two places is a mistake. Sorry.
TDanks76 is offline
Help 87 YJ belt? HARLEYX2 YJ Wrangler Technical Forum 9 06-26-2009 06:55 PM
My seat belt buzzer goes off when belt is in wildbadbill YJ Wrangler Technical Forum 7 04-15-2009 06:48 PM
New belt tensioner but my belt is still loose 02tjsport TJ Wrangler Technical Forum 4 02-26-2009 12:33 PM
how do I get the belt off/on rustyoke YJ Wrangler Technical Forum 10 05-29-2006 08:25 PM
4.2 v-belt to serpentine belt irocnrl89 YJ Wrangler Technical Forum 3 12-02-2005 12:26 PM
