Family Style Roll Bar - JeepForum.com
post #1 of 4 Old 12-24-2009, 11:29 AM Thread Starter
Cards89YJ
I have an 89 YJ Islander edition. It has the old CJ style roll bar that really doesn't cover the back seat very well. Where can I get a family stly roll bar that will bolt right in when I remove the old roll bar without having to make any mods?
Cards89YJ is offline
post #2 of 4 Old 12-24-2009, 11:49 AM
beachedjeepyj
I have heard that you can swap in one from a later model yj and it bolts up perfectly. But i have heard that some had to make minor modifications like elongating the holes to get the bolts to fit
edit: heres a thread that will answer most of your questions http://www.jeepforum.com/forum/f12/y...r-swap-516740/
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #3 of 4 Old 12-24-2009, 12:24 PM
Jeeeeeeeeeeeeep
I would check on Craigs List for a family style cage. One from a '92-'95 should bolt right in. You may have to elongate a couple holes to get it to fit. I did this swap, it was a little more work than I though just because some of the bolts were tough to get out but I managed, a little heat from a torch would probably help a lot.
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #4 of 4 Old 12-24-2009, 12:44 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
i just did the swap, make sure you get the seat belt assymblies for the rear. the old ones will not work
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
new family style roll bar and top ImpactFabWorks YJ Wrangler Technical Forum 5 06-19-2009 07:55 PM
What is the going rate for a family style roll bar? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 41 02-03-2009 07:57 PM
Putting the family back in family style roll bar YJames90 YJ Wrangler Technical Forum 12 04-27-2008 04:56 PM
Family style roll bar YJames90 YJ Wrangler Technical Forum 18 09-07-2007 02:55 PM
Where to get Family Style Roll Bar max3k YJ Wrangler Technical Forum 16 05-25-2005 07:37 AM
