Failed Smog Check - JeepForum.com
post #1 of 33 Old 05-15-2013, 10:51 PM Thread Starter
aldersonfilm
Failed Smog Check
So my YJ just failed smog due to NOx levels being WAY over the limit. Everything else passed, but both the 15mph and 25mph test were through the roof with NOx. Most people seem to say to change the cat and O2 sensor. Anybody else got any good tips?
I also heard that in California (where I am,) if you fail, you can apply to have the government co-pay for emission repairs and if it still fails, you get an exempt certificate. Any one know if that's true?
aldersonfilm is offline
post #2 of 33 Old 05-16-2013, 08:47 AM
dan240
dan240's Avatar
http://www.bar.ca.gov/80_BARResource...p_program.html
DMV website
1994 YJ 4.0L 5spd
SOA, 5100 Bilstein, TJ Flares, 35" BFG AT, 8.8, SYE, D30 truetrac/chromo, 1" MML
dan240 is offline
post #3 of 33 Old 05-16-2013, 09:13 AM
Que89YJ
Nox high someone just posted the temp sensor was an issue. The O2 sensor will usually make it run rich. Nox is lean. Check your fuel pressure and clean the throttlebody.
Que89YJ is offline
post #4 of 33 Old 05-16-2013, 09:49 AM
bill8bud
Check your engine codes to see if anything may be showing. I found my ecu temp sender was off. I had no check engine light showing
I have not retested yet but my milage went up 23%.
I bought a new cat but I have not installed it yet.
bill8bud is offline
post #5 of 33 Old 05-16-2013, 11:01 AM
Que89YJ
I was just mentioning you! Dont forget to post back when you get it smogged. Did you have the temp fault code Bill? Here is a thread for the codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #6 of 33 Old 05-16-2013, 11:23 AM
bill8bud
Yes I did.
bill8bud is offline
post #7 of 33 Old 05-16-2013, 11:31 AM
Reno72
Yes they will help pay, no there is no exempt status. This thread has what I did to pass along with other ideas
http://www.jeepforum.com/forum/f12/9...ilure-1475991/
Reno72 is offline
post #8 of 33 Old 05-16-2013, 06:04 PM Thread Starter
aldersonfilm
How do you check codes on the YJs? My old XJ was pre OBD1, so I've never had to do it. Also, where is that temp sensor?
post #9 of 33 Old 05-16-2013, 06:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would check codes as me tioned. You don't want to be labeled a gross polluter.
Luck Favours The Prepared
Anticanman is offline
post #10 of 33 Old 05-16-2013, 07:56 PM
Que89YJ
its in the link that I posted. video and what the codes mean.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #11 of 33 Old 05-17-2013, 09:10 AM
Aaron88
Glad I live in Alabama... NO inspection of any kind here.
Aaron88 is offline
post #12 of 33 Old 05-18-2013, 01:17 PM
Robob69
I had the same issue... Failed 5 times after: Tune up.. Oil Change, New Cat, New O2 Sensor, Coolant change... Then I replaced the Fuel Injectors with the 4 hole 19lb injectors and cleaned the TB and BAM... Passed with flying colors...
Robob69 is offline
post #13 of 33 Old 05-20-2013, 09:05 PM Thread Starter
aldersonfilm
Tested fuel pressure today and it's low. Like 22 psi low. Tried to pinch off the return line, but it's rock hard. This is some great new info, but what could it mean? Bad fuel pump or regulator? Are those the only two things it could be?
post #14 of 33 Old 05-20-2013, 10:41 PM
Robob69
Start with the Regulator.. I changed mine as well as the other things I had changed.. I had 41lbs on mine with and without the vacuum. Those dang little buggers are not cheap though.. $60 for it at my Orielly's and they had to order it.. GRRRR...
Robob69 is offline
post #15 of 33 Old 05-21-2013, 08:44 AM
Que89YJ
Did it increase when you disconnected the vacuum line? Did it hold pressure for 20 minutes ?
Fault codes:
No Start:
Que89YJ is offline
catalytic converter , emissions , failed smog , nox , smog
