Failed Smog, again. High HC at Idle. - Page 8 - JeepForum.com
post #106 of 118 Old 09-17-2012, 01:33 PM
piotrsko
Ok more stuff: you need a functioning egr if they test for egr. What they do is pull off the hose apply vacuum, and see if they can get it to "stumble". No stumble, no pass.
I pull plugs because the color the electrode is tells me rich or just right. I usually pull just one then put it right back in. I told you I am old.
piotrsko is offline
post #107 of 118 Old 09-17-2012, 02:32 PM Thread Starter
Michaelgoesrawr
Michaelgoesrawr's Avatar
The smog slip does say that they test for a functioning egr and that the one I currently have works. I'll go out there and suck on the tube and see what happens. Lol.
I can afford a fail if I have to, but I'd much rather not have to pay again. If there is something that would assure a pass and costs as much as a test($50 or so) I'd rather do that because I feel it'd help me in two years when I have to go again. I think an egr fits into that category but again, not sure lol.
Don't worry about being old. As far as I'm concerned the older you are the more knowledge you have.
Michaelgoesrawr is offline
post #108 of 118 Old 09-17-2012, 07:58 PM
piotrsko
yuch, 50 bucks a pop. the EGR assy probably costs that. I guess the days of 8 dollar no pass no pay are gone. Cheaper places by the DMV ? a friend with a sniffer? School class? Referee at the DMV, or have you gone that route yet?
I am reasonably certain within a 6th std deviation that you'd pass now on the sniff test. Of course it isn't my 50 bucks were spending here. BTW is your idle speed within spec?
Up side: now that you have this and aren't showing codes, EFI generally passes. some years you have to change the oil and get a bottle of fuel system cleaner. My trips yearly consist of showing up, writing check, get pass papers, go home. about that fast.
piotrsko is offline
post #109 of 118 Old 09-17-2012, 08:08 PM Thread Starter
Michaelgoesrawr
Yeah. 45.99 at Autozone. I pulled off the Vac line and gave it a suck when at idle and nothing happened. I have not gone the DMV route yet as I am still in communications with Howell about getting the required paperwork from them. It's going to be a PITA lol and I don't know anyone else that can do it for me. I posted earlier that when I first start it it idles around 1000-1200 for 30 sec and then kicks down to 7-8 about. I set the idle around 650 but when I pull the jumper and re plug in the throttle body connection it only goes down to 7-800.
post #110 of 118 Old 09-18-2012, 05:51 PM
piotrsko
OK idle sounds normal. the 1200 rpm bit is the system calibrating itself to a cold engine at today's atmospheric pressure.
The only thing you ought to need from Howell is the CARB exempt number and the vacuum sticker. That is all they sent me. They might want to verify you have the correct cal pack in, but they can do that by unit/ECM serial number and you can claim 50 state legal. May need to fail and go the referee route. Got receipts? packing slips? go online, print a copy of the vacuum routing on school bus yellow paper, put clear tape on it and stick it over the existing sticker.
OH wait, you did fail. I'd just go the referee route. While that used to be free, I bet it costs money now. Referee looks at system, sniffs it and gives you a slip to go get registered (or not). If you fail, then you decide how they want you to fix it. Might be less than $ 50.
piotrsko is offline
post #111 of 118 Old 09-18-2012, 06:04 PM Thread Starter
Michaelgoesrawr
I gave them the carb number on the throttle body but something was wrong with their records and things weren't matching up dunno why. The women said she had to talk to the boss and that shed call me back but she never did. The kit was bought off craigslist a few years ago so I don't have those stickers. I told them I would give them any info they wanted and needed that I could provide too.
post #112 of 118 Old 09-18-2012, 10:06 PM
NonRubicon
FWIW, the throttle bodies that come with the California legal Howell TBI kit have a brass tag on the TB with "E.O. D-452" stamped on it. If you don't have this tag, you may have a TB and ECM off a junkyard Chevy. Junkyard ECMs not have the right PROM/cal-pack for the Jeep applications that have been approved by the State of California.
NonRubicon is offline
post #113 of 118 Old 09-18-2012, 11:56 PM Thread Starter
Michaelgoesrawr
I have that tag and number. Had to clean it off but that's the info I gave Howell along with the item number.
post #114 of 118 Old 09-20-2012, 12:28 AM Thread Starter
Michaelgoesrawr
I ordered a new egr valve today which should be in Friday. I have school Friday and Monday so I'll probably get it smogged Tuesday afternoon.
post #115 of 118 Old 09-29-2012, 08:09 AM
piotrsko
did you ever pass? kinda fell off the map here.
piotrsko is offline
post #116 of 118 Old 09-29-2012, 09:35 AM Thread Starter
Michaelgoesrawr
Ah! No. I took it Tuesday and their machine was down so I went back Thursday and it failed. Worse this time. I don't have the report as the jeep is still at the shop because I doubt I can fix it. As far as I know no codes were thrown. I checked after driving it down the 15 to rancho and back Monday night and all was well. I think it was at 700 ppm at idle. I appreciate your help.
post #117 of 118 Old 10-05-2012, 09:26 AM Thread Starter
Michaelgoesrawr
The mechanics just called. From what I understand, the ECM and icm control advanced with how it's set up. It also had a bad icm and was sending poor signal to the coil. Hopefully I can pick it up before school. My girlfriend is still at home sleeping. I'll give more info when I get it if I can.
post #118 of 118 Old 10-05-2012, 06:07 PM Thread Starter
Michaelgoesrawr
It was a faulty icm and 3x advance that was screwing it up. Now it runs really well. After 350 of course. Psh.
4.2 , failed smog
E-Test failed High HC and CO at idle everything else PASS!! Jeepaw YJ Wrangler Technical Forum 7 02-19-2013 01:19 PM
94 YJ 4.0 Failed Ca. Smog Nox to high at 15 mph whitestroke YJ Wrangler Technical Forum 4 07-07-2012 09:59 PM
Failed CA Smog w/ high HC reading usmcwo1 YJ Wrangler Technical Forum 5 12-13-2009 08:56 AM
Failed Smog rugbygode2 YJ Wrangler Technical Forum 1 08-12-2008 06:12 AM
Failed Cal Smog mmontec_ss85 YJ Wrangler Technical Forum 9 01-17-2008 10:17 AM
