Failed NYC emissions. again. - JeepForum.com
post #1 of 9 Old 04-13-2010, 11:20 AM Thread Starter
anna29marias
Passes upstate NY with low emmisions standard test with no problem but cannot cannot register the car now without high emissions test. Two years ago, I had a throttle body cleaning and then passed but am sick of paying multiple times every time the car fails. There's no other issues like check engine light or too huge tires etc...
any advice?
I have a 93 YJ with less than 90,000 miles.
anna29marias is offline
post #2 of 9 Old 04-13-2010, 11:53 AM
triplej1954
Move to a location without the test.
triplej1954 is offline
post #3 of 9 Old 04-13-2010, 11:53 AM
Reverb
Depends if it just about fails or its substantial. If it almost passes I'd change the air filter then take it for a decent hard drive before you get tested - foot to the floor, then off, then foot to the floor a few times.
Reverb is offline
post #4 of 9 Old 04-13-2010, 12:58 PM
KnacK
What did they fail you on? Post your numbers that you got and what are required for passing and lets see what we can do.
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline
post #5 of 9 Old 04-13-2010, 01:47 PM
93jeepwrangler
1993 JK Wrangler
i have the same problem...my head gasket has a little leak init, so before i have an inspection done, i run enigine cleaner through it, let it fun for about 15 min and its fine.
93jeepwrangler is offline
post #6 of 9 Old 04-13-2010, 01:48 PM
jeep16
luckily the smog machine goes away in december
jeep16 is offline
post #7 of 9 Old 04-13-2010, 01:56 PM
warthog312
anyone else think we should have a sticky as to where emissions testing is done and to what specifics? it seems like there are a bunch of threads about it. i know here in chicago, OBD I is exempt, and OBD II only has a computer scan and you're done. just a thought...
warthog312 is offline
post #8 of 9 Old 04-13-2010, 02:19 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
no, there are enough stickys.
to the OP. I am in NY and don't have to pass any emissions with my 91. I am even missing certain factory options from the PO's actions.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #9 of 9 Old 04-13-2010, 02:24 PM
warthog312
ok, heres another idea, my old truck wouldnt pass emissions in its street/strip form so i registered it under my aunt's address in wisconsin and never had to deal with emissions again. just a thought.
Failed Emissions again! What the $@#% PiTRiFF YJ Wrangler Technical Forum 21 12-06-2009 07:51 PM
Failed emissions in NV, help? dwink YJ Wrangler Technical Forum 13 06-18-2009 05:49 PM
failed for emissions =( jeep n00b YJ Wrangler Technical Forum 78 10-21-2008 06:32 PM
Failed emissions. Need help JayJEEPguy YJ Wrangler Technical Forum 2 05-26-2005 08:03 AM
94 2.5 failed emissions Grand Wrangler YJ Wrangler Technical Forum 9 09-15-2004 10:28 AM
