Failed Emissions on '88 YJ - HELP!!! - JeepForum.com
post #1 of 9 Old 12-23-2001, 10:40 PM Thread Starter
achilles99
I finally found a Jeep that I really liked (could afford). Took it in for emissions, and it failed the carbon monoxide readings. Since this indicates a rich air/fuel condition, I'm guessing that it's probably an O2 sensor problem. Can anyone shed any light/experience on this? How can one check for a failed 02 sensor? Thanks in advance...
Oh, and it's a 2.5L 4 banger... I just changed the air filter, and the plugs and wires were changed by previous owner last year...
achilles99 is offline
post #2 of 9 Old 12-26-2001, 06:05 PM
glm 87 wrangler
About the best thing to do is to go ahead and replace it.The other exspensive way is to have the dealer run a check on the sensor.Also you may just do a basic tune up spark plugs etc.That may help but emmissions are a funny thing.How far was the co reading off.A few points or off the charts?
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 9 Old 12-27-2001, 09:37 AM Thread Starter
achilles99
I went ahead and changed the plugs and O2 sensor. I threw in a bottle of the carb cleaner stuff, too, just for good measure. I'm wondering if I should change the catalytic converter, too... what do you think?
post #4 of 9 Old 12-27-2001, 10:50 AM
glm 87 wrangler
Well most muffler shops can check them for you.Some even run this check for free.Look in your local yellow pages and call around.Ask if they check cats and if there is a charge.But at least have it check before replacing it.I would like to know how far off you were on the Carbon monoxide reading.If you are only a few points than a little tune up will go long way but if you are way off then you may have some bad sensors.NOTE more than one.But before you get wrench happy have the cat checked out.If you have a copy of the readings post them for me but give me the normal rating for your area.
post #5 of 9 Old 12-27-2001, 11:26 AM Thread Starter
achilles99
Reading Allowable Result
HC 189 215 Pass
CO% 4.11 2.69 FAIL
NO 1133 1415 Pass
CO+CO2% 15.8 6.0 min Pass
Catalytic PASS Gass Cap PASS
Hopefully, I'll go check this setup out with the replaced O2 sensor and new plugs. The wires were just changed out last year. Next step, I guess, is the catalytic? Thanks for the input!
post #6 of 9 Old 12-27-2001, 01:40 PM
glm 87 wrangler
Well if thats all you are off than the spark plug change and o2 sensor may be all you needed.How did your spark plugs look?
post #7 of 9 Old 12-29-2001, 06:38 PM
Colby Bruce
I own a '93 YJ 2.5, manual trans, that I just bought a cat converter for. I too live in Atlanta. I spent $210.00 for the converter and another $300.00 for a tune up and intake system cleaning. I passed, but think I have a cracked exhaust manifold and may need a new muffler. My cat was empty, all the honey comb stuff was gone. I detest the metro Atlanta emissions tests.
Colby Bruce is offline
post #8 of 9 Old 12-29-2001, 09:00 PM Thread Starter
achilles99
WHOA! You paid a lot... I hope that they truly did the work. I checked the service records on my Jeep, and the plugs, distributor, rotor button, and wires were supposedly changed last August. When I changed the plugs, they were CHOCOLATE brown, and the electrode was extremely broken down. So, I changed the plugs ($8), changed the O2 sensor ($65), and of course labor was free since I don't charge myself
The catalytic converter is only $65 at the auto parts store... WHO CHARGED YOU $210!!!?? To clean the intake system was pretty easy, too.
COLBY (or anyone else in Atlanta area) - Let me know if you need help with that stuff... no need to spend so much for "easy" maintenance items. I bought a Haynes manual, and it's pretty good about most of the stuff...
I'm going to burn through a tank of gas to let the carb cleaner stuff do it's thing, and then I'll let the board know how it affected my readings. Thanks for the advice...
post #9 of 9 Old 12-30-2001, 10:37 AM
Colby Bruce
Nash Jeep-Eagle in Lawrenceville did the tune up and intake cleaning. Yes, I realized later I might could have saved some money. The cat converter was done at a Norcross muffler shop. I work for the post office and could not take the time off to fool with it myself.
Failed Emissions again! What the $@#% PiTRiFF YJ Wrangler Technical Forum 21 12-06-2009 08:51 PM
Failed emissions in NV, help? dwink YJ Wrangler Technical Forum 13 06-18-2009 06:49 PM
just failed emissions what to do scott89 YJ Wrangler Technical Forum 1 03-03-2004 02:54 PM
Failed emissions for NO drew2000 YJ Wrangler Technical Forum 5 12-15-2003 08:21 AM
Failed Emissions... AllanAlxndr YJ Wrangler Technical Forum 5 06-09-2003 10:30 PM
