failed emissions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > failed emissions
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-18-2005, 02:10 PM   #1
phlex234
failed emissions
i failed my emissions test, the test said im getting to much air into the engine, i have the stock airbox on and everyhting, what im wondering is if someone could snap a pic of there airbox, to see what it looks like, is there like aa pipe or something that comes out of the passenger side of the airbox?
would replacing the O2 sensor help?
[SIZE=2][B]HI, my name is phlex234 and i approve this message because it's my destiny[/B][/SIZE]
[B]Jeep 2.5 Low Output club member #2
92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder[/B]
[URL=http://www.jeepforum.com/forum/showthread.php?t=155355]NEVER FORGET[/URL]
phlex234 is offline   Reply With Quote
Unread 06-19-2005, 02:54 PM   #2
oct7brian
I'd run seafoam though the engine, fill then tank with premium and replace the o2 sensor ... always made me pass
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline   Reply With Quote
Unread 06-19-2005, 06:44 PM   #3
drew2000
drew2000's Avatar
Too much air in the engine??? Are you sure it wasn't too much O2 in the exhaust?
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline   Reply With Quote
Unread 06-20-2005, 08:16 AM   #4
Wif
Too much air is what you need to pass emissions ..
[B]----------------------
Formally 88Jeepster
----------------------[/B]
[I]Who's[/I] in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Unread 06-20-2005, 09:56 AM   #5
phlex234
the guy was chinese, and he spoke spanish and chinesse only so he told "mucho aire" but im guessing too much air in the exhaust
this is what the test said
NO (PPM)
MAX MEAS
25 mph
891 1034
this is where i failed
