failed echeck today high NOx - Page 2 - JeepForum.com
post #16 of 33 Old 03-13-2014, 12:25 PM
Louie4
Rickety Wrecked Son!
Louie4's Avatar
Fixing the CCV (Closed Crankcase Ventilation) system may help. The back hose on the valve cover goes to a port on the intake. The front is a fresh air inlet going to the air box.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline
post #17 of 33 Old 03-13-2014, 04:29 PM Thread Starter
langwilliams
could someone post a pic of what the vac lines off the rear of the valve cover on the 4.0 is supposed to look like? thanks.
langwilliams is offline
post #18 of 33 Old 03-13-2014, 04:32 PM Thread Starter
langwilliams
here's what I have:
post #19 of 33 Old 03-13-2014, 08:32 PM
plym49
Originally Posted by 82gt View Post
I was able to induce a small vacuum leak, but finally replaced the cat and have been groovy ever since
That makes no sense as once the engine warms up and enters closed loop operation, the ECU will richen the mixture to compensate for the vacuum leak and maintain the stoichiometric ratio.
BTW, OP: running injector cleaner is meaningless.
plym49 is offline
post #20 of 33 Old 03-14-2014, 09:35 AM
jbeebe
I passed my echeck in CLE after running seafoam through the throttle body, then the rest in the gas tank. ran it around for ~50 miles, then took it
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #21 of 33 Old 03-14-2014, 09:56 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Run a can of seafoam (1/2 in the gas tank, 1/2 through a vacuum hose) change the plugs/wires/ cap/ rotor then go back it'll clean it up it works like a charm on my 89 with carter carb all the time
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline
post #22 of 33 Old 03-14-2014, 04:53 PM Thread Starter
langwilliams
thanks for the tips, going to do plugs an wires, cap this weekend. plugs look ugly an the one I pulled had a .053 gap!
post #23 of 33 Old 03-15-2014, 12:09 AM
Tom95YJ
Tom95YJ's Avatar
.035 is spec unless you have done a Tfi or hei ignition then .045
Tom95YJ is offline
post #24 of 33 Old 03-15-2014, 02:38 PM
photontraveler
Old Dude
photontraveler's Avatar
Put two cans of dry gas into a full tank of gas.......This has worked for me a number of times..............
"Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars."
photontraveler is offline
post #25 of 33 Old 03-15-2014, 05:42 PM
Xpress
Start with the basics, tune the sucker up. New plugs, cap, rotor, wires, clean your throttle body out, new air filter, change your oil/filter, and make sure it's running at operating temp.
Seafoam will clean out your injectors but not the throttle body, the throttle body is before the injectors. Fit a new fuel filter too.
High octane gas will actually make it run worse, unless it's already in piss poor shape. The higher octane fuel won't burn as efficiently in a low PSI engine like the 4.0 and will probably increase your emissions slightly. Use the lowest octane possible.
If all of that fails, you may be looking at a new cat indeed..
All about that unibody life.
Xpress is offline
post #26 of 33 Old 03-16-2014, 10:10 PM
czjeeper
Get the engine to operating temp. and introduce water into the brake booster line. This will vaporize and clean the combustion chamber most any carbon build up. Carbon build up will cause Nox levels to increase. Free and easy. But yeah, you will most likely need a cat at some point.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline
post #27 of 33 Old 03-18-2014, 11:46 AM Thread Starter
langwilliams
if anyone is wondering, i got it to pass. NOx standard is under 1047, i was at 1106. Ran some fuel injector/sea foam thru the tank. changed the plugs an wires. did the sea foam in the intake an let it sit a while. drove it hard an it smoked like a steam engine. went an got 4 gal of shell premium an put a bottle of heet in it. drove it some took it to the check station an it was 841. The tech said that is in standard but still a little high. I fig it'll need a cat for the next test, but who knows!
thanks for the tips
post #28 of 33 Old 03-18-2014, 10:07 PM
Tom95YJ
Tom95YJ's Avatar
if anyone is wondering, i got it to pass. NOx standard is under 1047, i was at 1106. Ran some fuel injector/sea foam thru the tank. changed the plugs an wires. did the sea foam in the intake an let it sit a while. drove it hard an it smoked like a steam engine. went an got 4 gal of shell premium an put a bottle of heet in it. drove it some took it to the check station an it was 841. The tech said that is in standard but still a little high. I fig it'll need a cat for the next test, but who knows! thanks for the tips
The premium fuel and heet probably made it run a little high premium fuel burns slower so it does not run as clean as regular in our old workhorse engines.
Tom95YJ is offline
post #29 of 33 Old 03-18-2014, 10:32 PM
Jeep43
Here in CA the max nox @ 15mph is 365. I failed at 659. After I changed my cat, plugs, and all filters I passed with a 1. The regulations are getting real strict every few years.
Jeep43 is offline
post #30 of 33 Old 03-19-2014, 04:29 PM Thread Starter
langwilliams
I lived in San Diego for a year while in the navy, I kept my truck registered an insured in Fla! Ohio isn't tightening standards that I know of, in fact on 5 or 7 counties still have to get checked an cars over 25 years old no longer require a check
