Factroy Horn Help - JeepForum.com
post #1 of 3 Old 03-16-2008, 06:28 PM Thread Starter
beachrusso
2010 JK Wrangler
Factroy Horn Help
I have no horn on my YJ can someone out there ad a pic of the factory horn set up and show the wiring as well. I am trying to put mine back together and need some info. Thanks
BEACHRUSSO
_________
l__l__\____\
l/-\l-_l_/ --*OllllllO*-
\__/ - \____H ___H
(O)__) (O)__)---o-)__)
beachrusso is offline
post #2 of 3 Old 03-16-2008, 07:19 PM
VT2BAD4U
Funny, my horn quit today. Found the relay to be the culprit. Look up by the fuse panel. It's the one by its self, just hanging there. Three prong relay, $10 at Advance Auto Parts.
Horn mounts on left fender, single wire hanging out of the wire loom about 8-10" from the radiator support.
Horn button creats a ground for the relay. Power is at the relay only when key is on.
VT2BAD4U is offline
post #3 of 3 Old 03-17-2008, 12:13 AM
wwhiker
Good info thanks, this reminds me that I need to fix my non working horn too
1990 2.5L FI, 5 speed, no mods.
wwhiker is offline
My horn is shot, shopping advice for a loud horn cj5mudman4x4 TJ Wrangler Technical Forum 7 07-28-2011 03:36 PM
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 05:24 PM
Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram??? atomicjoe23 YJ Wrangler Technical Forum 14 07-21-2009 07:39 PM
Anemic JK horn fixed! - Air Horn Install tturkstra JK Wrangler Technical Forum 11 10-03-2008 10:04 AM
factroy winch bumper?? 03stage2 JK Wrangler Technical Forum 47 03-08-2007 12:43 AM
