Factory gear ratio for Dana35 in 87 YJ? - JeepForum.com
post #1 of 15 Old 10-22-2001, 03:42 PM Thread Starter
SFM1AE2
What is it cause I think I need 4.11 gears?
87YJ I-6 Offenhauser intake Holley 4bbl MSD 6AL box
SFM1AE2 is offline
post #2 of 15 Old 10-22-2001, 03:55 PM
Wicked YJ
If it is a 4 banger it has 3.73.
If it is a 6 banger it has 3.07
94 Red YJ
4" RE lift, 2" body lift, 4.10 gears, ford 8.8 in the rear, powertrax No-Slip in the rear, lockrite in the front, complete custom roll cage by Carolina rock shop, and corbeau seats and 5pt. harnesses, and of course herculined
Wicked YJ is offline
post #3 of 15 Old 10-22-2001, 04:27 PM
Nightclaw
I thought 4-cylinders all had 4.10:1, and 6-cylinders had either 3.07 or 3.55:1...?
Nightclaw is offline
post #4 of 15 Old 10-22-2001, 07:03 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Actually ..
4cyl = 4.11 or 4.10 gears
6cyl = 3.07, 3.55, 3.73 gears
Mine, with tow package and all the extras has the 3.73 gears. My buddy that didn't have the tow package, but everything else has the 3.55 gears .. and another friend with the "cheap jeep" 6cyl has the 3.07 gears .. and he complains about it all the time!
If you look at the tag on the differential cover (if its still there), it will tell you which gears you have.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 15 Old 10-22-2001, 08:53 PM Thread Starter
SFM1AE2
So if my diff tag is no longer there how do I determine what my ratio is? What are the different options that rated different gear ratios?
SFM1AE2 is offline
post #6 of 15 Old 10-23-2001, 03:56 AM
AJ
'94 4.0 5spd... 3.73, and not enough for the 31's I'm running much less the 33's going on.
Chock your front wheels and place the back of your jeep on jack stands. Put the tranny in neutral and turn the rear driveshaft by hand, counting the number of turns it takes for 1 complete rotation of the tires. You'll see either about 3 1/2 ds turns = 3.55, a little past = 3.73. Or you could pull your diff cover, count the teeth on you r & P and do the math.
AJ is offline
post #7 of 15 Old 12-13-2013, 01:50 PM
Kingston
1987 YJ Wrangler
Whats a good everyday gear for daily driver use? I got 31" at tires n it pulls great, i just see alotta ppl useing a smaller gear but im assuming ppl are usein these for rock crawling since i see thats more popular up here
Kingston is offline
post #8 of 15 Old 12-13-2013, 03:59 PM
superj
My 87 has 3.07, if I remember properly. It was fine when it had 31s on it. I have an auto and 6 cylinder
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 15 Old 12-13-2013, 04:00 PM
superj
Oh ya, I have the top model for 87 so I have all the options and still have 3.07s so you can't go by model.
superj is offline
post #10 of 15 Old 12-13-2013, 04:10 PM
jeepguy85
1987 YJ Wrangler
I got an 87 4.2 5 speed and 3.07s. I am going to 3.73s. I know, I know 4.10s are better. I like the 3.73 ratio. It makes me smile.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #11 of 15 Old 12-13-2013, 04:43 PM
jserna
1987 YJ Wrangler
My 87 had 3.55 stock, 5 spd
jserna is offline
post #12 of 15 Old 12-13-2013, 07:12 PM
YJ4LIFE
ditto with the '89. www.car-parts.com can tell you the gear ratio options of almost any car or truck
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #13 of 15 Old 12-13-2013, 07:36 PM
Kingston
1987 YJ Wrangler
Is there a way to tell by the vin number?
Kingston is offline
post #14 of 15 Old 12-25-2013, 06:41 PM
jojojeep1
all i6 jeeps come with 307s if it comes with auto tranny they get 355 gears.
jojojeep1 is offline
post #15 of 15 Old 12-25-2013, 07:07 PM
jbolty
jbolty's Avatar
lots of bad information and wrong guesses in here but I bet the OP has figured it out over the last 12 years.
jbolty is offline
What gear ratio comes factory in a 95 yj with 4cyl and auto tranny? hartswelding YJ Wrangler Technical Forum 5 05-13-2009 07:55 AM
Gear Ratio from Factory? PSYCH0 TJ Wrangler Technical Forum 18 06-28-2008 08:13 AM
Factory Gear Ratio JeepN87 YJ Wrangler Technical Forum 4 03-05-2002 08:28 PM
What factory gear ratio do I have? JeepMax YJ Wrangler Technical Forum 6 03-04-2002 09:42 AM
factory gear ratio on a 93 Yj w/ 4.0 evilpsych YJ Wrangler Technical Forum 4 11-05-2001 10:22 PM
