factory gear ratio on a 93 Yj w/ 4.0 - JeepForum.com
post #1 of 5 Old 11-05-2001, 06:09 PM Thread Starter
evilpsych
evilpsych's Avatar
someone told me it was 3.07 from the factory.. anyone say different? that front and rear or what
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 5 Old 11-05-2001, 06:21 PM
bob91yj
I sure hope it's front and rear.
The axle ratio's have to be the same front and rear, or you would grenade the T-case. There are mud boggers that run different ratio's, but they are specialized just for the mud.
My 91 YJ Sahara came with 3.55's. Call your local Jeep dealer with the VIN number, or there should be a tag on the rear diff held on by two of the cover bolts with the info on it.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 5 Old 11-05-2001, 06:46 PM
jpwranglr9
you may have either 307 or 355. the 355 was an option. most likly you have 307's. and yes it may be different in the front. this is to make the jeep pull more in the front. something like 305 and 307. if there is no tag, just lift the jeep spin the tires onece and see if the driveshaft goes 3 or 3 1/2 times. if its 3
, than you have 307, and the other will be the 355
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #4 of 5 Old 11-05-2001, 07:24 PM
bob91yj
As a general rule, you can have 1% difference between axle ratio's. I was trying to eliminate any confusion about having 3.07's front, 3.55's rear. If you want to split hairs they can be different front to rear.
Bob
bob91yj is offline
post #5 of 5 Old 11-05-2001, 10:22 PM
Kev
Master of the Obvious
Kev's Avatar
While I had my '92 4.0L on the rack a couple of weekends ago, I spun a tire and confirmed what I suspected, 3.07 (driveline went around approx 3 times for one spin of the tire).
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
Factory gear ratio for Dana35 in 87 YJ? SFM1AE2 YJ Wrangler Technical Forum 14 12-25-2013 07:07 PM
What gear ratio comes factory in a 95 yj with 4cyl and auto tranny? hartswelding YJ Wrangler Technical Forum 5 05-13-2009 07:55 AM
Gear Ratio from Factory? PSYCH0 TJ Wrangler Technical Forum 18 06-28-2008 08:13 AM
Factory Gear Ratio JeepN87 YJ Wrangler Technical Forum 4 03-05-2002 08:28 PM
What factory gear ratio do I have? JeepMax YJ Wrangler Technical Forum 6 03-04-2002 09:42 AM
