Factory Gear Ratio - JeepForum.com
post #1 of 5 Old 03-04-2002, 04:15 PM Thread Starter
JeepN87
Factory Gear Ratio
does anyone know the factory gear ratio for a 5 speed 87 YJ 4.2L? Also, if i were to run 33x12.5s, would i need to re-gear? thanks
Nick
87 YJ 4.2L
JeepN87 is offline
post #2 of 5 Old 03-04-2002, 04:53 PM
rodgersmc
I'm thinking thats 3.83 ratio, and you wouldn't *need* a regear with 33's... I have same on 32's and don't mind. High end isn't great, but I can do 70-75 without too much problem unless I'm driving into strong wind.
That being said, it wouldn't hurt you to get 4.10's down the line.
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #3 of 5 Old 03-05-2002, 10:00 AM Thread Starter
JeepN87
thanks for your help. however, now I'm reading this chart that recommends at least 4.10 for all-terrain performance with 33s. I'm not really worried about going over 75 mph, just making sure i'll still have the use of all 5 gears. Would I still have use of my 5th gear? i'm also on a budget, and how much does it cost to regear? thanks
Nick
87 YJ 4.2L
JeepN87 is offline
post #4 of 5 Old 03-05-2002, 07:42 PM
jeepsonly
If you don't regear, you may not be able to go over 55. On our 94 YJ, we had 33x12.50's with the stock gears and every time we'd go on an overpass it would slow down. Poor little 2.5l - we really pushed it. Even with the 4.2l though, I think you'd have serious power problems on the highway.
BTW, on the 93 YJ, stock is 3.07 but I'm not sure about an 89.
Bill Hooven
Jeeps Only - A Yahoo-style directory for Jeep enthusiasts
jeepsonly is offline
post #5 of 5 Old 03-05-2002, 09:28 PM Thread Starter
JeepN87
thanks , i think i might have to go with a re-gear. however, i'm not too familiar with all that is involved with re-gearing. any suggestions on what gears i should switch to for what will mostly be a daily driver butalso have some off-road use? How much will it cost and what do i need to do? Thanks guys
Nick
87 YJ 4.2L
JeepN87 is offline
Factory gear ratio for Dana35 in 87 YJ? SFM1AE2 YJ Wrangler Technical Forum 14 12-25-2013 08:07 PM
What gear ratio comes factory in a 95 yj with 4cyl and auto tranny? hartswelding YJ Wrangler Technical Forum 5 05-13-2009 08:55 AM
Gear Ratio from Factory? PSYCH0 TJ Wrangler Technical Forum 18 06-28-2008 09:13 AM
What factory gear ratio do I have? JeepMax YJ Wrangler Technical Forum 6 03-04-2002 10:42 AM
factory gear ratio on a 93 Yj w/ 4.0 evilpsych YJ Wrangler Technical Forum 4 11-05-2001 11:22 PM
