Fabtech leaf springs - JeepForum.com
post #1 of 18 Old 10-11-2011, 09:13 PM Thread Starter
DigitalPunk
Has anyone used the fabtech 3.5" leaf sprigs?
They look pretty stout, have a military wrap and are a well known name, so I figured wth and bought some. Got them on sale from Amazon for $55 each! I currently have 6" springs and hate um, way to high of a lift.
Do the fabtech springs come with bushings? If not, anyone know if they use the standard stock size bushings?
DigitalPunk is offline
post #2 of 18 Old 10-11-2011, 09:56 PM
jeepnbrett
I've been running the fabtech springs for about 2 years. Very happy with them. They flex well and ride well with no sagging. As far as bushings go, they are a standard size poly bushing. Weather or not they come with bushings depends on who you are buying them from.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #3 of 18 Old 10-11-2011, 10:04 PM Thread Starter
DigitalPunk
Thanks brett, thats exactly the info I needed!
post #4 of 18 Old 10-12-2011, 12:36 AM
zte87
GIVE IT THE ONION
zte87's Avatar
I am running those now and I can confirm you have to buy the bushings separate. So far I love my spring and the only issue is you need to run at least a 1/2 inch lift shackle in the rear to keep the spring from contacting the frame at every little bump or when flexed out! I runs 7/8 boom shackle with mine and could't be happier! Here is a pic of the flex I get with mine keep in mine I don't run track bars or sway bars on my yj! And here is a before and after pic of the rear springs with and without the lift shackles!
Sent from my iPhone because I can!
zte87 is offline
post #5 of 18 Old 10-12-2011, 01:42 AM Thread Starter
DigitalPunk
Very nice! Your jeep looks sweet and flexes very nicely! I still can't believe the quality of spring you get for under $60! Thanks for the heads up on the shackles, luckily I think I have the same exact ones your running already.
So the bushings are the same size as OEM ones? Going to pick up a set of prothane leaf spring bushings for the stock springs and hope they fit.
post #6 of 18 Old 10-12-2011, 08:02 AM
zte87
GIVE IT THE ONION
zte87's Avatar
I am not sure on the bushings size I ordered my bushing kit from fabtech just to be on the safe side! Sent from my iPhone because I can!
zte87 is offline
post #7 of 18 Old 10-12-2011, 10:51 AM
Hghgrad
I just ordered a set of those. Was getting ready to spend $175 on used rc's...didn't realize the fabtech sprigs were cheap and could be ordered outside of the kit.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #8 of 18 Old 10-12-2011, 03:08 PM Thread Starter
DigitalPunk
FYI. They don't come with bushings. I will report back about the OEM size bushings fitting or not.
These springs look top notch! Better then a lot of springs that cost a lot more. They come with 5 leafs, nylon sliders, military wrap, installed center pins and even installed deg shims on the rear springs.
I was able to get them next day aired for $3.99 using my Amazon prime member ship.
I will take some good pictures of the springs and post them on here. I think this is one heck of a find.
post #9 of 18 Old 10-12-2011, 07:01 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Here is one of my fabtech springs next to my old 4 inch rc spring!
zte87 is offline
post #10 of 18 Old 10-13-2011, 04:20 PM Thread Starter
DigitalPunk
Another FYI.
The stock jeep YJ bushings fit into the fabtech springs. I ordered the prothane urethane bushings kit and all fits well. You need two boxes of them however.
post #11 of 18 Old 10-13-2011, 09:05 PM
weerwolv
Hi all,
Those who run this spring how is the on road feel? Can you compare it to OEM or OME or BDS?
For the price through Amazon I'm about ready to drop the hammer and pick them up.
weerwolv is offline
post #12 of 18 Old 11-23-2012, 08:40 AM
Toine
Hi,
Can anyone tell me what will be the actual height of this Springs after they ride in ?
Price for militairy wraps can't be beat I think, but how do they hold in front with V8 and heavy winchbumper/winch ?
Any response would be great ! Thanks
cj7 305 V8 TH-700R4 D300 lomax, front & rear D44 4.88 with detroit lockers, 4'' skyjacker lift, Doetsch Baja Ryders & u-bolt flip kits
Toine is offline
post #13 of 18 Old 11-23-2012, 10:02 AM
CRASHNDENT
fabtech 4"
I've been running them for a few months now, wheeled on them twice. They flex real well and ride a hell of a lot better than my last lift. I ordered my bushings kit ($53 shipped) from WFO (thanks Supertrey for the links) because of this thread http://www.jeepforum.com/forum/f12/f...stion-1402983/ .
By the way WFO ROCKS!!! The thread will answer a lot of your questions too. Also used the shocks info from the same thread (thanks Ashland82391)
Hope this helps
Don
CRASHNDENT is offline
post #14 of 18 Old 11-23-2012, 10:03 AM
CRASHNDENT
Originally Posted by Toine View Post
Hi,
The springs ended up giving me about 5 to 5.5 inch lift and i've got a honking big and heavy old 8274 warn winch up front.
post #15 of 18 Old 11-26-2012, 02:36 AM
Toine
Thanks Crashndent ! ,
I'll give them a try instead of the expensive Rubicon Express ones.
Toine is offline
fabtech springs? zte87 YJ Wrangler Technical Forum 4 08-12-2011 11:17 PM
Leaf Springs vs Coil Springs (Question) HanksRide TJ Wrangler Technical Forum 7 07-09-2011 12:55 PM
Outside Bushing Diameter for Fabtech 3.5" lift springs chupacabrah YJ Wrangler Technical Forum 4 05-03-2007 10:03 AM
fabtech leaf springs redjeep669 YJ Wrangler Technical Forum 4 11-30-2006 09:26 AM
Front leaf springs same as Rear leaf springs? JayJEEPguy YJ Wrangler Technical Forum 5 12-02-2003 10:53 PM
