eye dropper to fill gas tank?? - JeepForum.com
post #1 of 8 Old 08-01-2002, 11:31 AM Thread Starter
jeepthang23
I recently installed a 1.5" body lift on my YJ and now I have to pump gas very slowly. Is there a cure for this?
95 sahara hard top 4.0 six inches of lift with 35" tires. awaiting v-8
jeepthang23 is offline
post #2 of 8 Old 08-01-2002, 12:30 PM
Kev
Master of the Obvious
Kev's Avatar
Did the fill hose get kinked or bent. Make sure that there aren't any sharp bends or something pinching the fill hose that goes into the tank. HTH
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #3 of 8 Old 08-01-2002, 01:14 PM
LoOpY
i bought mine with the lift on it, and never have taken a real good look back there. all i know is that to pump gas i gotta put the handle/spout thingy in upsidedown or sideways and jam it as far in as possible, or else ill have gas everywhere. also it wont click off in time, so i gotta stand there like a goon with my ear to the tank listenin for the gas to start comin up the hose.
LoOpY is offline
post #4 of 8 Old 08-01-2002, 01:39 PM
battlestar
Where did you get a 1.5" inch body lift? All I've seen is 1",2", and 3" kits.
battlestar is offline
post #5 of 8 Old 08-01-2002, 11:19 PM
Jeepfreak81
Jeepfreak81's Avatar
i have to trickle mine in or it will overflow at a half tank, it never kicks off in time, no lift at all, i have a 20 gallon tank and usually can only get 15 in it unless i stand at the pump a half hour... only once did i get 19 in it
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #6 of 8 Old 08-02-2002, 03:01 AM
Quan
Quan's Avatar
My jeep likes to literally spit the 'gun' thing out when its done getting fuel... soon as the gun stops pumping it shoots it onto the ground splashing the leftover gasoline into the air and somtimes into my back seat.
There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.
Green Jeep Club Member #15
My Jeep Made Me Broke Club Member #2
93 YJ I-6 w/ stuff
Keep the greasy side down
Quan is offline
post #7 of 8 Old 08-02-2002, 07:55 AM
crownlvr
Check your vent hoses
It almost sounds as if you may have one of the vent hoses kinked. I bought my YJ w/ a 3" body lift and it is a pain to get gas. The same thing happens...if I go too fast, it cuts off.
You may want to consider putting an extension on the fuel filler hose. I did this and it helped tremendously.
You will need to get under your Jeep, but I strongly encourage you to get underneath and check for kinked vent hoses, etc...
Good luck!
1989 258ci--100K miles on original Peugeot (maintained by daily prayers)--33" all-terrains w/ 3" body lift (hey...that's how I bought it)--next upgrade...suspension lift...NO CHROME ON THIS JEEP (that's for you Lance!)
crownlvr is offline
post #8 of 8 Old 08-02-2002, 08:45 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Some of the CJ-7's came with "fuel cell" type fill hoses .. they were 2 1/2" diameter hose which allowed the gas to flow way fast!
I changed my tank and hoses and such in my S-10 to the large 2 1/2" fill hole, and I have no slow-downs now. When I replace my tank in my Jeep, I will be doing the exact same thing (I need a larger tank .. the 350ci engine sucks gas like I do slurpees!)
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Gas Tank won't fill jonesy02 TJ Wrangler Technical Forum 10 12-10-2009 10:23 AM
Gas tank won't fill?! bfaas TJ Wrangler Technical Forum 11 11-01-2009 02:01 PM
Gas tank will not fill all the way abadjay TJ Wrangler Technical Forum 30 09-30-2009 03:43 PM
Gas Tank Won't fill all the way jonesy02 TJ Wrangler Technical Forum 21 12-07-2007 07:49 AM
Couldn't fill my tank this AM?!? YlwColumbia TJ Wrangler Technical Forum 15 08-08-2004 12:49 AM
