External Slave Conversion Problems - Page 2 - JeepForum.com
post #16 of 25 Old 01-24-2014, 04:26 PM
Louie4
Are you sure the slave cylinder is not depressing the fork too much when it's bolted in causing it to slightly release it? That would cause it to slip but I wouldn't think the vibration.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #17 of 25 Old 01-25-2014, 08:56 AM
NW4wheeler
if all you changed was the bell housing it sounds like you didn't install the different front bearing retainer for the throw out bearing to slide on.
NW4wheeler is offline
post #18 of 25 Old 01-25-2014, 10:20 AM
flcracker
About to admit a stupid on my part but when we did the tranny swap to newer trans and external slave, it started vibrating and releasing very low to the floor.... went nuts trying to figure it out and found the bolts between the bellhousing and engine had backed out..... tightened them up and all is well once again
Just sayin....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #19 of 25 Old 01-25-2014, 05:18 PM Thread Starter
jesmac13
Bearing retainer was also replaced with the right one.
jesmac13 is offline
post #20 of 25 Old 01-25-2014, 05:19 PM Thread Starter
jesmac13
Just sayin....
I'll double check the bolts
jesmac13 is offline
post #21 of 25 Old 02-06-2014, 08:38 AM Thread Starter
jesmac13
Hey...I got the skid tightened down, engine bolts are tight - still having the same problem.
Here's a question though - how close is the throwout bearing supposed to fit over the bearing retainer "tube"? I remember there being a bit of play around the tube section. Is this normal, or should it be pretty well constrained?
jesmac13 is offline
post #22 of 25 Old 02-06-2014, 12:34 PM
HaskiE
...is the shift fork installed properly? you said it was used, bent maybe? is it nice and flat? maybe the other end came off the ball?
#theneverendingaxe
HaskiE is offline
post #23 of 25 Old 02-07-2014, 06:47 AM
whiskeywiz
Check the u bolt strap bolts while you're under there. Mine were loose, tightened up and eliminated the vibe... Just watchin your back while you're focused on that clutch! GL.
whiskeywiz is offline
post #24 of 25 Old 02-07-2014, 08:47 AM Thread Starter
jesmac13
Got it fixed last night before I saw this, but you nailed it! Where were you earlier? haha. Rear drive-shaft bolts were loose.
jesmac13 is offline
post #25 of 25 Old 02-07-2014, 09:32 AM
whiskeywiz
No kiddin. Lol. Cool. You were focused and I know it can be annoying some suggestions that seem obvious. Didn't think of it til today anyway. Used blue thread locker on those bolts, right?
